neljoe
Moderator
Como as perguntas relacionadas com "versões" do Vag-com (quais as diferenças entre elas, etc...) andam a aparecer por todo o lado... aqui vai a resposta:
_________________________________________________
Release 11.11 posted 11 Nov. 2011
Includes partial support for VW Crafter vans. Communications with all control modules; functions supported: Control Module ID and Advanced ID, Fault Codes (Read and Clear), Supported Codes, Security Access, and Adaptation. Other functions such as Measuring Values, Output Tests, and Basic Settings will be added in future versions.
New, more universal Airbag Coding Assistant.
New "Upload Debug/Log File" function in Applications Dialog
Completely revised and expanded ROD (ODX) Data.
New USB Drivers. Now compatible with the latest PCs which use Fresco Logic USB3 chipsets.
Re-factored DTC routines which interpret DTC data, including enhanced interpretation of status byte for DTCs in UDS modules.
New area to display additional info for Basic Settings.
Added data types 0B, 0D, 0F to Generic OBD-II Mode 9.
New version of LCode. Thanks to Niels in Denmark!.
Revised and expanded Label Files. Thanks to Sebastian!
Many other small fixes and improvements, as well as everything which was introduced in Beta Versions 11.2 - 11.10.
Release 10.6.4 posted 18 Apr. 2011
Label File Name and additional Information now shown in Control Module Identification
New Firmware for HEX+CAN interfaces
Improved control module documentation (Label and .ROD files)
Release 10.6.3 posted 7 Dec. 2010
Support for new Gateways installed in many PQ25 and PQ35 models since 08.11.2010
Release 10.6.2 posted 23 Nov. 2010
Improved handling of Subsystems ("Slave Modules") in UDS/ODX
Support for Audi A1 (8X Chassis)
Improved support for 2011 Jetta (chassis code AJ)
Improved support for vehicle identification in those instances where a VIN is not available.
Release 10.6.1 posted 4 Sept. 2010
Support for Subsystems ("Slave Modules") in UDS/ODX
Improved display of fault codes on UDS/ODX modules
New Firmware for HEX+CAN and Micro-CAN interfaces
Release 10.6 posted 30 June 2010
Supports Basic Settings on control modules using the new UDS/ODX/ASAM protocol.
Adds new UDS addresses and updated ODX data for 2011 models.
Support for new addresses in latest cars
Improved Readiness Screens with additional info
Full 64-bit support on systems which can use it.
New CODES file, now with over 14,000 fault code and measuring value texts.
Updated Label files; improved documentation for new and existing models.
Includes everything introduced in Beta versions versions 912, 10.3, and 10.4.
Release 908.0 posted 30 August 2009
Supports Measuring Values, Output Tests, and Adaptations on control modules using the new UDS/ODX/ASAM protocol.
Adds new UDS addresses and updated ODX data for 2010 models.
Includes support for TP1.6 protocol which is required for the 6J Ibiza and speeds up access on many modules in other models.
The Select Control Module screen now shows "Installed Modules" rather than "Common Modules" if the car being worked on is new enough to have a proper CAN Gateway.
Modified SRI Screen to show more info and force user to select a job before proceeding.
Adds drop-box function selection in Basic Settings and Adaptation.
Reads Mileage stored in many EDC16 ECUs.
New CODES file, now with over 13,000 fault code and measuring value texts.
New USB drivers for enhanced PC compatibility and stability.
New firmware for HEX interfaces required for compatibility with 6J Ibiza
Updated Label files; better documentation for new and existing models.
Too many other improvements to list here. For details see the Beta 812, 904, and 907 pages
Release 812.4
Measuring Values for UDS/ODX/ASAM Control Modules.
These control modules do not support traditional VW/Audi "Blocks" or "Groups" of live data. Instead, measuring values must be selected from a list via Advance Measuring Values. Up to 12 values can be selected and viewed, graphed, or logged at the same time:
This functionality requires a control module specific "data dictionary" file, so as new modules are introduced, it becomes more important than ever to be sure you are using the latest version (including the latest Data Version).
Support for new UDS addresses.
We believe that VCDS now supports addresses for all UDS control modules in production as of this writing.
Support for TP1.6 CAN Protocol.
Required by ABS system used in 6J Chassis Ibiza.
The Select Control Module screen now shows "Installed" modules instead of "Common" modules.
On CAN based cars which have a proper Gateway that supports an Installation List, VCDS now shows exactly which modules are installed on the Select Control Module screen:
It does take about 1.5 seconds to get the list from the Gateway, so a bit of a delay when clicking [Select] is normal/expected. When used on a car which does not have a Gateway that supports an Installation List, the old-style "Common" tab will still be shown. For customers who use VCDS primarily on older cars which do not have an Installation List available, this feature can be disabled on the User Interface and Identification tab of the Options screen.
Support for logging data simultaneously from both ECUs on cars using Dual ECUs.
For example the B7 RS4 and R8 and various W12 engines:
New HEX Firmware Version 1.79
Required for compatibility with the 6J Chassis Ibiza and also speeds up getting the Installation List in Auto-Scan and for the Installed tab of the Select Control Module screen by booting the interface in intelligent mode. However, this means that HEX interfaces no longer boot in "dumb" mode and are no longer compatible with 3rd party applications, so the "Boot in Intelligent Mode" feature can be disabled on the Options screen in those cases where compatibility with a 3rd party application is required.
Supports Transport Mode on a number of new models
Such as the R8, new Ibiza, facelift Touareg, facelift A6.
Improved Support for Coding of Slave Modules
Correct coding information is now supplied to the Long Coding Helper and the master module's Workshop ID is used when coding is sent to the slave module in those instances where the slave module does not yet have a Workshop ID.
SRI Reset button moved to main screen.
It has swapped position with Control Module Finder because SRI Reset is used much more frequently. In addition, the SRI Reset function has been optimized in a manner which we believe will eliminate compatibility problems previously reported on certain PCs. [Save] and [Clear] buttons on the Control Module Finder screen are now functional.
Display EDC Mileage now works with many EDC16 ECUs.
Support for Readiness on US Common-Rail TDI-140 Engines.
Support for Coding Suggestions on a number of new Airbag control modules.
Support for new South African CityGolf 1400 ECU.
Support for Non-Uniform Fault Code Subtypes
In SAE/ISO "B" and "C" codes VW sometimes uses non-standard Subtypes which are now properly supported in VCDS with a new CODES.DAT file containing over 12,600 texts.
Optimized position of Session Log and Advanced Measuring Value select dialogs
Based on user-selected window size and actual size of the PC's screen.
Session Log Filename dialog now allows browsing and opening an existing file
If a VIN is available, existing files are filtered for those containing the VIN.
Improvements in Generic OBD-II:
- Turbo Mode and No Wait for 2nd Controller for increased sample rate.
- Compatibility with BMW models with newer Automatic Transmissions.
- [Copy] and [Save] buttons now functional in Mode 1.
Installer Modified to work with Windows 7.
Release Notes:
Works only with Intelligent Interfaces (HEX, KEY and Micro-CAN).
Works on Windows 98, ME, 2000, XP, and Vista. Windows 95 is not supported.
Release 805.1 posted 24 August 2008
Adds support for latest new model cars such as Audi Q5, Passat CC, new Skoda Superb, VW Sirocco and Passat CC.
Numerous small bug-fixes and stability enhancements.
Release 805.0 posted 29 May 2008
New Product Name: VAG-COM is now VCDS™.
Full support for control modules using the new "Service 22" identification methods.
Support for control modules using the new UDS/ODX/ASAM protocol.
The following functions are supported:
Control Module ID (including Advanced ID), Coding, Security Access, and Fault Codes.
New Session Log capabilities.
Support for Generic OBD-II Mode 10.
Support for vehicles with dual ECUs, or example the RS4 and W12 engines.
Both ECUs are accessible simultaneously via address 31 for Basic Settings such as TBA.
Revised Adaptation screen to support the much longer Long Adaptations now appearing in some control modules.
Revised Advanced ID screen for increased flexibility handling the various data items appearing in the latest control modules.
New internal Gateway Coding Assistant (required for Audi B8 platform cars).
Much improved documentation (Label Files) for many older cars.
For more details, see our Beta 711 and Beta 804 pages.
Release 704 posted 5 April 2007
Fully compatible with Windows Vista
Automatic Updates
New Service Reminder function
Support for Guided Readiness Scripts.
Optical Bus Diagnosis
Battery Coding Assistant
Ability to save and retrieve Advanced Measuring Block configurations
Enhanced compatibility with latest model cars.
New universal Installer with USB driver pre-installation.
For more details, see our Beta 702 page.
This version is no longer supported. Users should update to a newer version.
Release 607 posted 14 July 2006
New Advanced Measuring Blocks function
Freeze Frame Data shown in-line with Fault Codes and in Auto-Scan
Fault codes now indicate whether a MIL is on.
Automatic Detection of installed modules (CAN cars only) in Auto Scan.
Auto-Scan includes Hardware Part Numbers on those modules where it's available separately.
New Supported Codes function.
New EDC15+ Mileage function (odometer reality-check).
New Acceleration Measurement function (performance calculator)
Regular and Long Coding screens combined into one.
New VAG-Scope version 1.9 compatible with Advanced Measuring Blocks.
New TDI-Graph version 1.4 compatible with V6 TDIs.
Updated Label Files
Generic OBD-II now includes Info Types 08 and 0A in Mode 9.
New more informative Installer.
Support for new Micro-CAN interfaces.
Numerous other fixes and enhancements introduced in Beta 606.
Release 512 posted 24 December 2005
Supports Selective Output Tests
Supports Coding of Slave Modules
Adds control module mapping functions.
Support/intergration of Long Coding Helper applications such as Niels Ezerman's excellent
LCode.exe (included with this distribution of VAG-COM):
Revised Options Screen with parameters grouped more logically.
Supports alphanumeric Long Adaptations
Revised and expanded Label Files to document many more systems.
As usual, big thanks and lots of credit are owed to Sebastian and Michael.
Revised and expanded CODES file. Now over 9000 codes -- completely up to date.
Numerous other fixes and enhancements introduced in Beta Versions 505, 506, and 510.
Release 504 posted 05 April 2005
Compatible with all the latest car models, engines, & transmissions.
A big thanks and lots of credit are owed to Sebastian and Michael.
Revised and expanded CODES file for improved clarity and new codes for 2006 models.
Incorporates all new features including generic OBD-II functionality introduced in Beta 500.x.
Adds generic OBD-II capabilities
Release 409 posted 03 October 2004
Clear All DTCs functions
Support for Transport Mode ON/OFF for Golf-5 Platform and Audi A8(4E) chassis cars.
Fixed incompatibility with older Sharan (7M platform) 09 modules.
CODES file enhanced with texts for 2005 models.
Ability to decode Readiness bits for modern TDI engines
Support for selectable window sizes for higher-resolution laptops.
New Label File redirection methods
New Version 1.7 VAG-Scope
New Version 1.3E of TDI-Graph
SAVE CODES button on Fault Codes Screen.
This version is supported only for customers who are using long obsolete "dumb" or third-party interfaces.
Release 404 posted 29 April 2004
Support for HEX+CAN interfaces and all 2005 Model VW/Audi/Seat/Skoda passenger vehicles including those requiring a direct CAN connection for diagnostics with an appropriate CAN-capable interface.
Includes all additional enhancements introduced in Beta versions 401.2, 402.3, and 403.1.
Adds support for the KEY-COM and KEY-USB Interfaces.
Adds enhanced labels for Measuring Blocks, Adaptation Channels, and Recode screens.
Adds suggested coding values for Airbag controllers.
Release 311 posted 16 November 2003
Support for all 2004 Model VW/Audi/Seat/Skoda passenger vehicles using the K-Line for diagnostics.
"Turbo" mode in Measuring Blocks for ME7 and EDC16 ECUs using KWP-2000 protocol for diagnostics. Up to 34 samples per second. Requires HEX-COM or HEX-USB interface.
Enhanced keyboard support throughout VAG-COM
Browse function when opening Log files.
Ability to Log Measuring Block Group 000.
New "Tabbed" Select Control Module Interface with buttons for all control module addresses currently supported by the VAS-5051/5052.
Enhanced Measuring Block formulas. Adds support for a number of new data-types, and fixes all known bugs in formulas. All formulas have been verified against our VAS-5052 with latest software.
Adds Freeze Frame data for Fault Codes on control modules using the KWP-2000 protocols.
Adds Advanced ID function for control modules using the KWP-2000 Protocols.
Assorted Bug Fixes.
Adds Support for the HEX-USB Interface, including updated USB Drivers compatible with both the TWIN-USB and the HEX-USB.
Completely rewritten KWP-2000 routines. Compatible with numerous new control modules found in Touareg, Phaeton and others including EDC-16 and MED-9.
Adds Output Test (03), Adaptation (10) and Access Authorization (16) for control modules using KWP-2000.
Release 303 posted 24 March 2003
Adds the long awaited Auto-Scan ("00 Scan") feature.
Adds support for the TDI Timing Checker "Plug-In"
Tremendously expanded and completely revised CODES file. Now over 7000 codes, including codes for new models like the Touareg, Phaeton, NB Cabrio, etc.
Includes new version (1.3a) of VAG-Scope which supports graphing of 10 fields found in
Group 000.
Numerous small enhancements
Fixes for some "glitches" in HEX-COM and TWIN-USB support.
Adds support for new HEX-COM and TWIN-USB interfaces.
Adds support for VAG-Scope graphing "Plug-In"
Release 208 posted 12 August 2002
Adds Basic Settings, Login, Recode, and Readiness for those control modules that use the KWP-2000 protocols in 2001 and newer (mostly 2002+) cars.
Adds Control Module Finder.
Adds a 256 Color Mode for old PC's on which previous versions of VAG-COM didn't look very nice.
Numerous small tweaks and bug-fixes.
Beta 0.81 posted 14 March 2002
New Self-Installing -- no need to manually create folders or shortcuts.
Supports 7-Digit PINs (Secret Key Codes)
Supports control modules using KWP-2000 protocol -- Shows Controller Info, Reads and Clears Fault Codes, shows & allows logging of Measuring Blocks. Other functions will be added soon.
Incorporates numerous other small improvements previously available in Alpha 0.80 and Alpha 0.81.
Additional Label Files and Codes
Added warning pop-up for the Airbag Controller Issue.
Beta 0.78 posted 08 July 2001
Adds Data Logging
Adds Print Codes from the Fault Code Screen
Fixes a rarely occurring bug causing some fault codes not to be shown (only when there are a large number of them)
Lots of new Label Files, a few new Codes.
Added De-Activate button to facilitate license transfers
Beta 0.75 posted 18 Mar 2001
Huge CODES file update. Over 3400 codes!
Adds the ability to view 3 Measuring Block Groups simultaneously.
Adds support for user-supplied Measuring Block Labels
Adds complete support for "hybrid" measuring block data-type common in Digfant-3 ECUs and AG4 Transmissions.
May work with some USB<->RS232 adapters, but this is not officially supported. If it works for you, fine. If it's "flaky", try a PC with a "real" port!
Beta 0.71 posted 06 Feb 2001
Adds OBD-II Compatibility Test
Adds support for Magnetti-Marelli ECUs common on South American VWs.
Beta 0.70b posted 10 Jan 2001
Adds Output Test, Single Reading, and View Readiness.
Low-Level protocol drivers rewritten to include error detection and correction.
Better support for non-optically isolated interface adapters
Adds checksums to Serial Numbers and Activation Codes so typographical errors will be rejected.
Various small bug fixes
Beta 0.65 posted 30 Oct 2000
Adds Measuring Blocks, Basic Settings, and Adaptation Functions.
Improved Controller Initialization and Protocol Options.
Runs as "Shareware" without Activation. Requires Activation Code for full functionality.
Version 0.65 is not longer supported, users should update to a newer version.
Beta 0.50 / 0.50a Posted 16 May 2000
@ http://www.ross-tech.com/vcds/revisions.html
Revision History, Major Releases:
Release 812.4
Release Notes:
Automatic Updates
Updated Label Files
Assorted Bug Fixes.
Group 000.
Adds Data Logging
