Bom dia pessoal. Agora parece k tudo me acontece. Este fim de semana descobri k a minha carrinha sofreu uma martelada de 100.000km, ou seja, neste momento tem 254.000km, e hoje ao por a carrinha a trabalhar acendeu a luz do AIR BAG!!! É uma A4 B6 1.9 TDI, 130cv de 6v, de 2004/07 Qual será o problema?? Quem puder ajude-m por favor Obrigado Cumprimentos
Re: Luz AIR BAG acesa Address 01: Engine Labels: 038-906-019-AVF.lbl Part No: 038 906 019 LJ Component: 1,9l R4 EDC G000SG 5934 Coding: 00002 Shop #: WSC 63251 WAUZZZ8E05A038814 AUZ6Z0D0268836 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Component: ABS/ESP front 4529 Coding: 04255 Shop #: WSC 06435 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AB Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 63251 1 Fault Found 00716 - Air recirculation Flap Positioning Motor (V113) 41-00 - Blocked or No Voltage ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 F Component: int. Lastmodul RDW 0517 Coding: 01001 Shop #: WSC 63251 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 63251 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 P Component: Lenksáulenmodul 0611 Coding: 04242 Shop #: WSC 63251 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 930 T Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 00001 Shop #: WSC 00044 WAUZZZ8E05A038814 AUZ6Z0D0268836 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: Redir Fail! Part No: 4B0 919 887 E Component: BNS 4.2 H05 BNO 0050 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl Part No: 8E0 959 433 AR Component: Komfortgerát T85 1512 Coding: 06976 Shop #: WSC 63251 Part No: 8E1959801B Component: Tõrsteuer.FS BRM 0205 Part No: 8E1959802B Component: Tõrsteuer.BF BRM 0205 1 Fault Found 00956 - Key 2 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 186 J Component: concert II GRO 0008 Coding: 01001 Shop #: WSC 63251 1 Fault Found 00858 - Connection; Radio ZF Output to Antenna Amplifier 36-00 - Open Circuit Deu tudo isto, mas isto foi no sabado, e já fiz desde lá 650km e só hoje é k a luz acendeu!!! O k será?
Re: Luz AIR BAG acesa tens de ligar ao VAG é agora com a luz acesa... se no sabado nao deu erro de Airbag tambem a luz estava apagada... ele nao vai adivinhar erros futuros ne???
Re: Luz AIR BAG acesa Pois, mas se reparares melhor, tem ali um erro k diz Air Bag, mas nesse dia a luz tava apagada!!!
Re: Luz AIR BAG acesa Amigo, eu nao vejo erro nenhum relacionado com airbags nesse log........... Tens que limpar os erros todos, andar com o carro uns km, e fazer novo log... para agente te conseguir ajudar....
Re: Luz AIR BAG acesa Ok, vou fazer isso então!! E então k erro é este: Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 63251 000 00000 No fault code found.
Re: Luz AIR BAG acesa ololololololoo nao e erro nehum.... NO FAULT CODE FOUND means -> erros não encontrados... logo, tudo isso é o que o Modulo Airbag tem de informação.. Coding, Part-number, etc... erros ai 0...
Re: Luz AIR BAG acesa já tou a perceber. Mas agora acendeu a luz. Tenho de ver o k é!!! Obrigado pela explicação
Re: Luz AIR BAG acesa Verifica tambem se não existirá alguma ficha debaixo dos bancos que esteja mal ligada...
Re: Luz AIR BAG acesa Acabei de fazer isso e.....agora ficou a acender tb a luz de ESP (triangulo com ponto de !!!, e um seta em volta do triangulo, tudo cor de laranja)!!!
Re: Luz AIR BAG acesa Boas... A bem pouco tempo tive essa luz do airbag ligada... O problema centrava-se no facto de haver mau contacto... Solução... Desligar as fichas que tenho debaixo dos banco da frente... Aplicar WD40 e secar tudo muito bem... voltar a ligar tudo... Depois foi so correr outra vez o vag-com... apagar o erro... e voilá... (o erro continuava a aparecer porque estava guardado na centralina e por causa disso a luz não apagava) Espero ter ajudado... Cumps 8)
