Pessoal ca esta o scan mas tenho aqui algumas faltas quem me pode ajudar
VAG-COM
Windows Based VAG/VAS Emulator
Version: Release 607.3-UD
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000
Self-Diagnosis Log
Tuesday,29,April,2008,11:25:07
VIN Number: License Plate:
Mileage: Repair Order:
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN Number: WAUZZZ
Address 01: Engine
Part No: 038 906 019 JT
Component: 1,9l R4 EDC G000SG 1572
Coding: 00002
Shop #: WSC 63351
WAUZZZ AUZ6Z0B0278563
5 Faults Found:
17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
P1586 - 35-10 - - - Intermittent
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-10 - - - Intermittent
18097 - Powertrain Data Bus: Implausible Message from Elect. Load Controller
P1689 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
P1570 - 35-00 - -
Readiness: 0 0 X X X
Address 03: ABS Brakes
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
No fault code found.
VAG-COM
Self-Diagnosis Log
Page 2
VIN Number: WAUZZZ License Plate:
Address 08: Auto HVAC
Part No: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
41-10 - Blocked or No Voltage - Intermittent
00474 - Control Module for Immobilizer
49-10 - No Communications - Intermittent
Address 09: Cent. Elect.
Part No: 8E0 907 279 C
Component: int. Lastmodul RDW 0203
Coding: 00001
Shop #: WSC 63351
Address 15: Airbags
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 63351
VAG-COM
Self-Diagnosis Log
Page 3
Address 16: Steering wheel
Part No: 8E0 953 549 P
Component: Lenksáulenmodul 0711
Coding: 00042
Shop #: WSC 06435
8 Faults Found:
00883 - Ignition Switch (D) Terminal S
57-10 - Electric Circuit Failure - Intermittent
01320 - Control Module for Climatronic (J255)
01304 - Radio
49-00 - No Communications
01303 - Telephone Transceiver (R36)
01301 - Control Module for Voice Recognition (J507)
01747 - Sensor for Heated Steering Wheel (Z36)
30-00 - Open or Short to Plus
01426 - Controls in Steering Wheel (E221)
Address 17: Instruments
Part No: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 00000
Shop #: WSC 20446
3 Faults Found:
01316 - ABS Control Module
01304 - Radio
VAG-COM
Self-Diagnosis Log
Page 4
Address 46: Central Conv.
Part No: 8E0 959 433 BA
Component: Komfortgerát TA7 1310
Coding: 07008
Shop #: WSC 63351
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
6 Faults Found:
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
61-00 - Won't De-Safe
01562 - Right Rear Door
61-10 - Won't De-Safe - Intermittent
00956 - Key 2
00936 - Electric Window Switch in Front Passenger Door (E107).
27-00 - Implausible Signal
End --------------------------------------------------------------------------------------------------
Tive introduzir o ficheiro assim pois nao sei como se consegue colocar um ficheiro pdf
