O meu contakilometros deixou de aparecer o ok ... Quando s liga a chave... Fiz o vag com e apareceu isto :VCDS Version: Beta 912.0
Data version: 20091201
Saturday,23,April,2011,18:01:37:60804
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 01: Engine Labels: None
Part No: 038 906 012 A
Component: 1,9l R4 EDC 0000SG 2801
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 M
Component: A3 KLIMAVOLLAUTOMAT_D77
Coding: 03143
Shop #: WSC 06435
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 3008
Coding: 00104
Shop #: WSC 04380
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 900 B
Component: KOMBI+WEGFAHRS. M73 D16
Coding: 00140
Shop #: WSC 04380
Part No: Ident
Component: Nr. Wegfahrs.:AUZ5Z0Y9173025
Ident.-Nr. Wegfahrs.:AUZ5Z0Y9173025
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Part No: 8LO 862 257 E
Component: ZV-Pumpe D03
Coding: 00000
Shop #: WSC 65535
2 Faults Found:
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
End ---------------------------------------------------------------
Gostaria de ajuda nao consigo entender algumas das coisas aqui descritas ....
Desde ja o meu obrigado....
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
Readiness: N/A
Coding: 13304
Shop #: WSC 06435
Coding: 03143
Shop #: WSC 06435
1 Fault Found:
Coding: 00104
Shop #: WSC 04380
Coding: 00140
Shop #: WSC 04380
Part No: Ident
No Faults Found
Coding: 00000
Shop #: WSC 65535
2 Faults Found:
35-00 - -
35-00 - -
