Preciso de ajuda....
O meu contakilometros deixou de aparecer o ok ... Quando s liga a chave... Fiz o vag com e apareceu isto :VCDS Version: Beta 912.0
Data version: 20091201
Saturday,23,April,2011,18:01:37:60804
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 01: Engine Labels: None
Part No: 038 906 012 A
Component: 1,9l R4 EDC 0000SG 2801
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 M
Component: A3 KLIMAVOLLAUTOMAT_D77
Coding: 03143
Shop #: WSC 06435
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 3008
Coding: 00104
Shop #: WSC 04380
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 900 B
Component: KOMBI+WEGFAHRS. M73 D16
Coding: 00140
Shop #: WSC 04380
Part No: Ident
Component: Nr. Wegfahrs.:AUZ5Z0Y9173025
Ident.-Nr. Wegfahrs.:AUZ5Z0Y9173025
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8LO 862 257 E
Component: ZV-Pumpe D03
Coding: 00000
Shop #: WSC 65535
2 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
End ---------------------------------------------------------------
Gostaria de ajuda nao consigo entender algumas das coisas aqui descritas ....
Desde ja o meu obrigado....
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
Readiness: N/A
Deve Aver alguma ***** na parte eletronica do motor (centralina?)
Boa sorte
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
Readiness: N/A
Coding: 13304
Shop #: WSC 06435
Coding: 03143
Shop #: WSC 06435
1 Fault Found:
Coding: 00104
Shop #: WSC 04380
Coding: 00140
Shop #: WSC 04380
Part No: Ident
No Faults Found
Coding: 00000
Shop #: WSC 65535
2 Faults Found:
35-00 - -
35-00 - -
e se carregares no botao para fazer o check up aparecem os simbolos(temperatura,reserva,etc...):?:
Nao aparece luzes nenhumas no display , nem no klimatronic, nem no botao das luzes ,nem no cinzeiro .....
no ultimo fala nisto:
01366 - Inaugurado Devido Bater Sinal
Possíveis Causas
* Saída do teste realizado em Airbag Control Module (J234)
* veículo envolvido no acidente
o Airbag Control Module (J234) Bater dados armazenados
* Fiação / conectores de / para o Airbag Control Module (J234) com defeito
Possíveis Soluções
* Verificar / códigos de falha clara
* Verifique a fiação / conectores de / para o Airbag Control Module (J234)
001206 - Sinal de Duração de ignição fora de tempo
Possíveis Causas
* Interruptor de ignição defeituoso
* Ligação entre o instrumento cluster (J285) e Controle Climatronic (J255) com defeito
* Instrumento de cluster (J285) com defeito
* Climatronic Control (J255) com defeito
Possíveis Soluções
* Mude de ignição Verifique
* Verifique a fiação entre o instrumento cluster (J285) e Controle Climatronic (J255)
* Grupo de instrumentos de verificação (J285)
* Controle Check Climatronic (J255)
18058/P1650/005712 - Powertrain Data Bus: Falta Mensagem do Instrumento de cluster
Os possíveis sintomas
* Light indicador de anomalias (MIL) ON
Possíveis Causas
* Fuse (s) com defeito
* Databus Fiação e / ou conector (s) de / para o conjunto do instrumento (J285) com defeito
Possíveis Soluções
* Controlar o fusível (s)
* Verifique Databus Fiação e / ou conector (s) de / para o conjunto do instrumento (J285)
* Verifique / substitua Cluster Instrumento (J285)
Confira o valor Blocos de Medição (MVB)
Espero ter ajudado... ;)
Ja vi fusiveis e nao encontrei nenhum queimado ..
Já desliguei o quadrante e voltei a ligar e nada tudo igual ...
Desliguei a bateria ..
Ficou tudo igual e nao vi nada desligado nem fios cortados ...
O a mais estranho e nao sabendo s isso tem haver uma coisa com a outra o pq dos botoes do ac nao terem luz o quadrante ter ficado com mt pouca luz como o modulo de ac tb .....
humm.... isso será falta de alimentaçao de corrente para a iluminação.. mas sera o mais certo um fusivel... em termos de despistagem, podes tentar tambem trocar o comutador das luzes a ver se nao podera ser dai...
Boas RockyBoy
Ja agora podes m dizer qual o fusível em questão pois já tentei ver e não vi nada queimado ...
E o pq do comutador de luzes ...
Pelos vistos tb tives t o msm problema qual a soluçao q fizes t pra resolver isso ..
Boas RockyBoy
eu nunca teve esse sintoma, uma vez fiz um chante sem querer num minimo e queimou m fusivel, e comoe ra de noite so o mudei no dia a seguir, e fiquei sem luzes no quadrante, nos difusores e nao me recordo se mais algguma coisa..
Aconteceu alguma coisa ao carro, ou isso foi de um momento para o outro? Tenho uma a4 com o msm erro que o teu no modulo do motor!
O teu carro liga?
Penso q o erro seja este :
1 Fault Found:
Readiness: N/A
O meu carro liga so nao memoriza o kms percorridos nem a data nem da a informaçao de temperatura nem o ok inicial antes de ligar o motor, alem disso nao tenho luz no botao das luzes nem nas teclas do ac ... E sim foi de um dia pro outro ... Mas de resto o carro anda e faz tudo normal pelo menos nao dei conta de mais nada ....
1 Fault Found:
Readiness: N/A
Ja tive um caso, que era o IMMO desactivado... eu proprio ja o comprovei...
mas tambem tive esse problema no meu outro painel que estava avariado...
meti este painel e desapareceu o erro... no outro caso, activou-se o IMMO na centralina e voila.. o erro desapareceu..
Bem andei tanto tempo nisto e hoje consegui resolver o erro, eram umas relés que tem por baixo da centralina, nao davam sempre contacto em condiçoes, spray de contactos etc e tal! e lá desapareceram os erros todos, tanto do motor como quase dos modulos todos tinha isso! Sim era o erro de 18058 - Powertrain Data Bus: Missing Message from Instrument Cluster mas nao era so do instument's, era tambem do ABS, dos airbags, AC etc!! Mas pronto para já ficou bom ! tinha problemas no immo, mas era pk nao havia comunicaçao (Erro anterior) do immo para a centralina, tb gravei o immo na centralina só para o carro pegar e andar! Mas agora que resolvi a verdadeira questao do problema, vou voltar a por o immo no quadrante!
