Olhem o que encontrei hoje numa sucata :twisted:
Isto vale apena?
Quanto vale?
Pelo que me disseram este é uma edição especial porque tem as vielas em magnesio, é verdade?
O carro está a andar, so ta todo c@gado porque estava debaixo/dentro do mato.
Bodywork
Type: 4/5S SAL
Number of doors: 4
Dimensions
Wheelbase: 2669 mm 105.07 in
Track front: 1440 mm 56.69 in
Track rear: 1432 mm 56.37 in
Length: 4408 mm 173.54 in
Width: 1714 mm 67.48 in
Kerb weight: 1180 kg 2601.45 lb
Fuel capacity: 70 l 18.49 US gal
More Peugeot technical data:
Engine
Type: 4-S
DOHC
4 valves per cylinder
Main bearings: 5
Bore x stroke: 86.00 mm. × 86.00 mm.
Bore / stroke ratio: 1
Displacement: 1998 cc 121.92 cu in
Compression: 10.4
Fuel system: Bo MP 3.2 fuel inj.
Aspiration: Normal
Catalytic Converter: Y
Max. output: 154.1 PS (152 bph) (113.3 kW) @ 6500 rpm
Max. torque: 183 Nm (134.9 lbft) (18.6 kgm) @ 3500 rpm
Coolant: Water
Specific torque: N/A
Performance
0-100km/h: 9.8 s
Quarter mile: 17 s
Kilometre: 30.7 s
Top speed: 215
Would-be bankers search for jobs in new places
Chasis
Engine location: Front
Engine alignment: Transverse
Steering: rack & pinion PAS
Turning circle: 11
Brakes: VeDi/Di-S-ABS
Transmission: 5M
Drive: F
Top gear ratio: 0.75
Final drive ratio: 4.42
Isto vale apena?
Quanto vale?
Bodywork
Type: 4/5S SAL
Number of doors: 4
Dimensions
Engine
Type: 4-S
DOHC
Main bearings: 5
Compression: 10.4
Aspiration: Normal
Coolant: Water
Performance
0-100km/h: 9.8 s
Quarter mile: 17 s
Kilometre: 30.7 s
Top speed: 215
Chasis
Turning circle: 11
Transmission: 5M
Drive: F
