Seat Ibiza 6L acendeu varias luzes em andamento :S HELP
Ola.
Vinha eu na boa a chegar a casa. Deparo-me com BIP vindo do quadrante.
Tinha a luz da direcçao assistida ligada a piscar. Depois começou piscar luz travao de mao. Depois acendeu a luz do airbag. E por fim acendeu a luz do motor
Desliguei carro voltei a ligar tudo OK.
Passado 1 minuto. FIco sem direcçao assistida e apagaram se as luzes ficou apenas airbag e tambem motor.
E acontece ficar com a direcçao muito pessada. passado bocado fica boa.E sempre assim.
Liguei ao VAG com deu bastantes erros olha vejamos
Friday,23,January,2009,23:15:58:26365
VCDS Version: Release 805.3
Data version: 20090213
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
Address 01: Engine Labels: 045-906-019-AMF.lbl
Part No: 045 906 019 BG
Component: 1,4l R3 EDC 0000SG 5180
Coding: 00102
Shop #: WSC 06402
VSSZZZ6LZ5R174034 SEZ7Z0E2969512
2 Faults Found
18061 - Please check DTC Memory of ABS Controller
P1653 - 35-10 - - - Intermittent
18045 - Powertrain Data Bus: Missing Message from Electric Load Controller
P1637 - 35-00 - -
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS.lbl
Part No SW: 6Q0 907 379 AA HW: 6Q0 907 379 AA
Component: ABS 8.0 front H03 0001
Revision: 00000000 Serial number: 00000000000000
Coding: 0000008
Shop #: WSC 06403 785 00200
No fault code found.
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6L0 820 045
Component: Klimaanlage X0840
1 Fault Found
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00012
Shop #: WSC 06402
2 Faults Found
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01309 - Power Steering Control Module (J500)
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 AD
Component: 03 AIRBAG VW5 0010
Coding: 12339
Shop #: WSC 06401
1 Fault Found
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 801 A
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 00134
Shop #: WSC 00050
3 Faults Found
01322 - Control Module for Multi-Function Unit (MFA) (J501)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0068 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
2 Faults Found
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AE
Component: LenkhilfeKYO V957
Coding: 10161
Shop #: WSC 06402
5 Faults Found
00566 - Steering Assistance Operation
27-10 - Implausible Signal - Intermittent
01321 - Control Module for Airbags (J234)
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 0K Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
Part No: 6Q2959802A
Component: 0K Tõrsteuer.FS KLO 0202
Part No: 6Q2959801A
Component: 0K Tõrsteuer.BF KLO 0202
a bateria está ok? o alternador está a carregar bem?
verifica isso e as ligações que ligam na bateria.... mede as tensões se tiveres um multimetro.
Antes ir trabalhar vou ao mecanico deixar a carroça. Ele deve ter Vultimetro e vou medir a bateria.
Ja deixo resultado.
Boas.
Hoje de manha fui logo a SEAT fizeram me o diagonostico. Disseram que devia ser pontos de massa ou entao fios partidos.
Mas como sei que na SEAT é muito caro. Vou ao meu mecanico para ele ver que pode fazer. Mas vou-lhe indicar essa situaçao da bateria para ele trocar.
Boas .
Troquei a bateria e tive a ver o nivel do oleo da direcçao assistida e tava ok.
Continua com mesmo problema :S ja nao sei que fazer mais ....
como disseram na seat, verifica os pontos de massa, e os cabos que saem da bateria.... dá uma vista de olhos pela cablagem a volta da bateria, motor de arranque e do alternador.
Se é electronica ou hidraulica nao faço mesmo ideia.
Ja deixei no mecanico" Electrecissta ". Vamos a ver no que vai sair.
Mas ideias sao precisas . Espero bem que venha NOVO.
quando tinha ibiza fez-me algo parecido. mas so acendeu a luz do abs e do travao de mao. fui ao mecanico e tinha sido a banda magnetica do cubo que foi à vida. isto nos travoes de traz que ainda eram de tambor
Efectuado o teste a situaçao mantem -se identitica.
:S
Ao fim de 2 semanas sem carro problema ainda por resolver :S
Ibiza 6L acendeu varias luzes em andamento Ajuda please
Ola.
Ola.
