pessoal...meu argolas quando eu passo o vag aparece esse erro:
16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
Possible Symptoms:
- Malfunction Indicator Light (MIL) ON
Possible Causes:
- Fuel Pump Relay (J17) faulty
- Hoses/Pipes to/between Components faulty/clogged
- Secondary Air Injection Pump (V101) faulty
- Secondary Air Injection Pump Relay (J299) faulty
- Secondary Air Injection Solenoid Valve (N112) faulty
Possible Solutions:
- Check Fuel Pump Relay (J17)
- Check Hoses/Pipes to/between Components
- Check Secondary Air Injection Hoses/Pipes for Carbonization
- Check Secondary Air Injection Pump (V101)
- Check Secondary Air Injection Pump Relay (J299)
- Check Secondary Air Injection Solenoid Valve (N112)
o carro não tem nenhum sintoma aparente...
alguem ja teve esse erro sabe como resolver??? revisei as mangueiras todas não achei nenhum problema...
abraço!
