[Ajuda]Erros Vag-Com
Boas...
Sou inexperiente em Audi e por inerência no Vag-com, hoje fiz um auto scan e estou em estado de chock...
Preciso da vossa ajuda, vou colocar a listagem de erros...
Cá vai...
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 8L0 906 018 M
Component: 1.8L R4/5VT G 0002
Coding: 05710
Shop #: WSC 00000
5 Faults Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
16946 - System Voltage Too Low
P0562 - 35-10 - - - Intermittent
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-10 - - - Intermittent
18017 - Crash Shut-Down Activated
P1609 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 E
Component: ESP 20 CAN V004
Coding: 18446
Shop #: WSC 01236
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00040
Shop #: WSC 01236
Address 15 -------------------------------------------------------
Controller: 8N8 909 601
Component: Airbag Front+Seite 1005
Coding: 10102
Shop #: WSC 01236
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
Address 17 -------------------------------------------------------
Controller: 8N1 920 880 H
Component: KOMBI+WEGFAHRS. M73 D55
Coding: 01144
Shop #: WSC 46200
XXXXXXXXXXXXXXXXX AUZ5Z0C2275062
3 Faults Found:
01315 - Transmission Control Module
49-00 - No Communications
01304 - Radio
01305 - Databus for Infotainment
37-00 - Faulty
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
1 Fault Found:
Address 35 -------------------------------------------------------
Controller: 8N8 962 267
Component: Zentralverrieg.,DWA D04
Coding: 04682
Shop #: WSC 01236
5 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00668 - Supply Voltage Terminal 30
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00957 - Key 3
09-10 - Adaptation Limit Surpassed - Intermittent
Address 45 -------------------------------------------------------
Controller: 8N8 951 177 A
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00010
Shop #: WSC 01236
End -------------------------------------------------------
Cumprimentos,
Tiveste um acidente?
Alguns dos erros têm a ver com sensores de colisão..
Antes de tdo podes experimentar apagar os erros tdos e dar uma volta com o carro e fazer novo scan pa ver quais os erros q ainda ficam activos, dps posta o novo scan
Eu não tive nenhum acidente, mas sei que o carro teve um pequeno acidente antes de vir para as minhas mãos, mas foi reparado na Audi...
Podes explicar-me por favor como se apagam os erros???
E os restantes erros???
Obrigado pela ajuda,
Cumprimentos,
Acho estranho ter sido reparado na audi e terem deixado o carro sair de lá assim sem eliminarem tdos os erros :confused:
No vag-com tens uma opção "clear all dtc's" fazes isso, dps vais dar uma volta ou deixas andar um dia ou dois, faz novo scan e coloca aqui
Mas foi mesmo reparado na Audi, também acho muito estranho mas das marcas também já espero tudo...
Vou então já tentar apagar todos Erros, e amanhã volto a fazer um novo scan e coloco aqui,
Cumprimentos,
seleccionas select control module , vais entrando nos modulos respectivos e tens a opção para apagar.
Cumprimentos
Já apaguei todos os erros, agora vou dar uma volta com o bicho e amanha faço um novo scan...
obrigado pela ajuda,
Cumprimentos
Depois de ter apagado todos os erros fiz 130km +/-, agora fiz novo scan:
Coding: 05710
Shop #: WSC 00000
Coding: 18446
Shop #: WSC 01236
Coding: 00040
Shop #: WSC 01236
Coding: 10102
Shop #: WSC 01236
1 Fault Found:
Coding: 01144
Shop #: WSC 46200
3 Faults Found:
01304 - Radio
37-00 - Faulty
Coding: 04682
Shop #: WSC 01236
Coding: 00001
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 01236
Deu menos erros, mas deu...
Cumprimentos,
Tá melhor :D
Tens rádio de origem montado? S não, os do address 17 em principio são disso.. O erro dos airbags frontais parece uma falha de alimentação, é estranho.. A luz do quadrante está sempre acesa? Acende e apaga qdo ligas a chave?
Viva,
O rádio é o de origem, a luz dos airbags tem um comportamento normal ,acende e depois apaga !!!
:s , mas já ta melhor...
Viva,
tens o radio mal codificado no quadrante ( modulo 17 ) canal 62 em adapta (10) sem labels no teu vagcom é complicado... mas tenta por 0 no canal 62 e faz scan. (anota o codigo do canal 62)
A cena do airbag é complicada, ja tive isso num golf V e nem na VW conseguiram limpar.. talvez um commander 1.4 limpe a eprom da centralina do airbag...
o airbag e por causa de algum rele, tenta tirar a protecção debaixo do volante ai estam todos os reles ve se estao todos bem encaixados e logo a kuatro parafusos com cabos ligados como se fosse um ponto de massa mas de corrente em dois tens cabos vermelhos e nos outros dois cabos pretos com risca amarela verifica se estam bem apertados isso deve resolver o problema
se nao resolver experimenta com uma bateria nova
a mim aconteceu me por causa do som como traga muita energia saliam erros destes por todos lados
