Caso percebas ingles:
Re: [VAG-COM] Persistent Airbag Light
wiring and / or clock spring in steering wheel. Did you have the steering wheel
off latley or did you remove battery. i would also look for the ground junction
point (usually under battery) and clean this extremely well.
Mark Everall <ragussa_s6@...> wrote:
If it's any help, I had the same fault code in my '96 S6 Avant.
There was a blown fuse in the fuse box.
Regards
Mark
Sebastian Stange <Sebastian@...> wrote:
Normally the airbag warning light switches on when you switch on the
ignition, 1-2 seconds later it goes off. In case of an error it's on,
then switches off and comes on again. My guess is your's doesn't switch
off in between.
Check the wiring between airbag control unit and instrument cluster.
Sebastian
mudmonkey wrote:
> Greetings, searching the archives, I found a number of airbag lights that
refuse to turn off;
> however, I couldn't find any with the same symptoms.
> The car is a '96 A4 and the light recently came on. I was waiting on a
replacement
> instrument cluster (the original tach/speedo had stopped working) so I paid no
heed.
> Today, I installed the replacement instrument cluster and the airbag light
remains on. I
> plugged in VAG-COM and clear the codes. Turned on the car, and the light came
right back
> on. I dumped the code from VAG-COM and got:
> Control Module Part Number: 8A0 959 655 D
> Component and/or Version: Airbag V AUDI D00
> Software Coding: 00127
> Work Shop Code: WSC 06334
> 1 Fault Found:
> 01025 - Trigger for On Board Diagnostic Lamp; Malfunction
> 31-00 - Open or Short to Ground
> So, it is telling me that the lamp trigger is bad. Strange since the lamp is
solidly lit. This is a
> rather dumb question, but there are no other Air Bag lamps in the IC. What is
this code
> talking about?
> Thanks for your insights.
Esta ai uma que desconhecia, existe um ponto de massa debaixo da bateria que deve ser limpo de vez em quando... :S
