Bem....
Os prints dos "advanced identification" não eram necessários.
1º Os problemas/erros existentes num scan que colocaste num post no final de Junho deste ano já estão resolvidos / não existem?
acho que permanecem.. alias fiz um scan e tem mais erros..
2º Tens um radio Concert II e não um RNS-E, correcto?
o radio é o concertII
3º Tens volante Multi-funções?
não
4º Coloca aqui um scan completo actual de todos os modulos, sff.
VAG-COM
Windows Based VAG/VAS Emulator
Version: Release 607.3-UD
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000
Self-Diagnosis Log
Thursday,17,September,2009,01:42:42
VIN Number: WAUZZZ8PX4A033345 License Plate:
Mileage: Repair Order:
Chassis Type: 8P - Audi A3
Scan: 01 02 03 08 09 0F 15 16 17 18 19 22 25 36 37 42 44 46 47 52
55 56 57 62 69 72 76 77 7D
Address 01: Engine
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Coding: 0000072
Shop #: WSC 06435
2 Faults Found:
19559 - Motor for Intake Manifold Flap (V157): Malfunction
P3103 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 11000100
Torque: 0.0 Nm
Torque: 354.0 Nm
16785 - EGR System: Insufficient Flow
P0401 - 000 - - - Intermittent
Freeze Frame:
RPM: 1407 /min
Torque: 82.0 Nm
Speed: 22.0 km/h
Load: 27.1 %
Duty Cycle: 14.7 %
Bin. Bits: 11000000
Mass Air / Rev.: 310.0 mg/str
Mass Air / Rev.: 560.0 mg/str
Readiness: 1 2 0 0 0
Address 03: ABS Brakes
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0055942
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0120
Address 09: Cent. Elect.
Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
Component: Bordnetz-SG 1.0 H30 0701
Coding: 008C570000141000000000000000000000
Shop #: WSC 00000
Part No: 8P1 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00064784
Shop #: WSC 00000
2 Faults Found:
00153 - Left Windshield Wiper Motor (V216)
004 - No Signal/Communication - Intermittent
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Address 15: Airbags
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0010602
Shop #: WSC 06435
Address 16: Steering wheel
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 007 0030
Coding: 0000002
Shop #: WSC 06435
Address 17: Instruments
Part No SW: 8P0 920 900 B HW: 8P0 920 900 B
Component: KOMBIINSTR. VDO H27 0050
Coding: 0004013
Shop #: WSC 00012
Address 19: CAN Gateway
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Coding: 3D0F0BC2070100
Shop #: WSC 00000
Address 25: Immobilizer
Address 42: Door Elect, Driver
Part No: 8P0 959 801 A
Component: Tuersteuerger. H09 0010
Coding: 0000016
Shop #: WSC 06435
Address 44: Steering Assist
Part No: 1K1 909 143 L
Component: EPS_ZFLS Kl.7 0402
Address 46: Central Conv.
Part No: 8P0 959 433 B
Component: KSG H02 0030
Coding: 0A8800186D288505484A016000
Shop #: WSC 06435
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
2 Faults Found:
00332 - Control Circuit for Tank Flap
007 - Short to Ground
00955 - Key 1
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 47: Sound System
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH22 0080
Address 52: Door Elect, Pass.
Part No: 8P0 959 802 A
Coding: 0000016
Shop #: WSC 06435
Address 56: Radio
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H51 0060
Coding: 0001021
Shop #: WSC 06435
4 Faults Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 211
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 211
Freeze Frame:
Bin. Bits: 10
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 211
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 191
Mileage: 109658 km
Time Indication: 0
Date: 2008.12.15
Time: 11:11:51
Address 77: Telephone
Part No SW: 8P0 862 335 HW: 8P0 862 335
Component: FSE_255x H10 0070
Coding: 0000307
Shop #: WSC 00000
Address 7D: Aux. Heat
Part No SW: 1K0 963 235 A HW: 1K0 963 235 A
Component: PTC-Element 0303
End --------------------------------------------------------------------------------------------------
Dealer/Shop Name:
Self-Diagnosis Log
Thursday,17,September,2009,01:43:57
VIN Number: License Plate:
Gateway Installation List: 1K0 907 530 B
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
obrigado pela rápida resposta.. este é o verdadeiro sentido do forum
já agora agradecia também ajuda com estes erros..
Nota: O modulo BT aparentemente está mal codificado, mais conclusões só depois das respostas ás perguntas, excluindo a hipótese de poder estar com avaria.
