Re: a4 b6 falha
Boas, fiz hoje teste com o vagcom e deu-me alguns erros mas apaguei meti o carro a trabalhar e depois só me deram estes:
Monday,18,March,2013,14:45:38:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E83A102630 Mileage: 740km/459miles
Address 01: Engine Labels: None
Part No: 038 997 019 G
Component: 1,9l R4 EDC 0000SG 7000
Coding: 00002
Shop #: WSC 01031
VCID: 254BEF4DBFFA271
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
VCID: E5CB2F4D7F7A671
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 2649E841C2FC2C9
3 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00474 - Control Module for Immobilizer
49-00 - No Communications
27-10 - Implausible Signal - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 C
Component: int. Lastmodul RDW 0203
Coding: 00001
Shop #: WSC 00000
VCID: 32610411FE34409
1 Fault Found:
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 01031 261 94079
VCID: 3E7920216A6C949
1 Fault Found:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
011 - Open Circuit - MIL ON
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00002
Shop #: WSC 00000
VCID: 36693801125C5C9
1 Fault Found:
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 MX
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00000
Shop #: WSC 00222
VCID: 860908C1A23C8C9
WAUZZZ8E83A102630 AUZ6Z0*0000000
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AR
Component: Komfortgerát T85 1210
Coding: 04704
Shop #: WSC 63351
VCID: 81031BDD8B12AB1
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
Entretanto medi também os injetores ao relantim e deram-me estes valores:
Chamam-se os entendidos para uma ajudinha sff
Cumprimentos
