Boa noite aqui estao os erros k tenho na carrinha.. o imobilizador ja esta resolvido e os erros ja os apaguei e nao voltaram, so o motor é k esta a funcionar mal....
Address 25: Immobilizer Labels: 7M3-953-257.lbl Part No: 7M3 953 257 Component: IMMO 0008 Coding: 00003 Shop #: WSC 00000 VCID: F6E38053D23266AE3EF-4A3A WVWZZZ7MZ5V036829 VWZ1Z0E2782689
4 Faults Found: 00750 - Warning Lamp 28-10 - Short to Plus - Intermittent 00750 - Warning Lamp 31-10 - Open or Short to Ground - Intermittent 01176 - Key 07-00 - Signal too Low 01176 - Key 65-10 - Unauthorized - Intermittent
-------------------------------------------------------------------------------Address 01: Engine Labels: 038-906-019-AJM.lbl Part No: 038 906 019 LQ Component: 1,9l R4 EDC 0001AG 1594 Coding: 00001 Shop #: WSC 00020 VCID: 71E9334F3B5CC1966BD-4A3A WVWZZZ7MZ5V036829 VWZ1Z0E2782689
Address 02: Auto Trans Labels: None Part No: 09B 927 750 L Component: AG5 Getriebe 09B 0248 VCID: 3561C75F0FB4ADB6775-5072
1 Fault Found: 00792 - A/C Pressure Switch (F129) 35-00 - -
VCDS Self-Diagnosis Log Tuesday,20,June,2017,16:20:49:62939 Page 2
2 Faults Found: 01166 - Engine Torque Signal 03-10 - No Signal - Intermittent 01045 - Tiptronic Switch (F189) 27-10 - Implausible Signal - Intermittent
1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent
VIN: WVWZZZ7MZ5V036829 License Plate:
-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 7M3-907-37x-ABS.clb Part No: 7M3 907 379 G Component: ABS FRONT MK25 0102 Coding: 0007177 Shop #: WSC 00020 000 00000 VCID: 4189A38F1B7C1116DBD-5072
-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 7M3-907-040.clb Part No: 7M3 907 040 J Component: CLIMATRONIC MPV GP 0007 Coding: 00020 Shop #: WSC 00020 VCID: 3561C75F0FB4ADB6775-2566
-------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: None Part No: 7M3 962 258 AH Component: Multifunkt.Einh 0002 Coding: 04113 Shop #: WSC 00020 VCID: 800FE68B80F6581E143-5000
3 Faults Found: 00668 - Supply Voltage Terminal 30 07-10 - Signal too Low - Intermittent 00978 - Lamp for Low Beam; Left (M29) 30-10 - Open or Short to Plus - Intermittent 00979 - Lamp for Low Beam; Right (M31) 30-10 - Open or Short to Plus - Intermittent
1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent
No fault code found.
VCDS Self-Diagnosis Log Tuesday,20,June,2017,16:20:49:62939 Page 3
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl Part No: 1C0 909 605 F Component: 0E AIRBAG VW61 0Q0M 0003 Coding: 12357 Shop #: WSC 00020 VCID: 275D1D17C518CF26F59-5000
-------------------------------------------------------------------------------Address 17: Instruments Labels: 7Mx-920-xxx-17.lbl Part No: 7M3 920 920 H Component: KOMBIINSTRUMENT VDO V61 Coding: 13411 Shop #: WSC 01234 VCID: 3561C75F0FB4ADB6775-5072
1 Fault Found: 00771 - Fuel Level Sensor (G) 30-10 - Open or Short to Plus - Intermittent
-------------------------------------------------------------------------------Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 00020 VCID: F0EFB64BB056489EE43-5072
