Vag - Fault Code - Ajuda Urgente
Pessoal o Ibiza de um amigo meu apresenta estes erros... preciso de ajuda a identificar o problema em concreto de momento o seat nao da sinal de motor de arranque... agradeço ajuda urgente :S
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 37 44 46 55 56
Address 01: Engine
Part No: 045 906 019 BQ
Component: 1,4l R3 EDC G000SG 7627
Coding: 00102
Shop #: WSC 06402
2 Faults Found:
18097 - Powertrain Data Bus: Implausible Message from Elect. Load Controller
P1689 - 35-00 - -
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-10 - - - Intermittent
Readiness: 1 1 0 0 0
Address 03: ABS Brakes
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H05 0002
Coding: 0002199
Shop #: WSC 06402
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 52
Mileage: 49049 km
Time Indication: 0
Address 08: Auto HVAC
Part No: 6L0 820 043 E
Component: CLIMAtronic PQ24 3805
No fault code found.
Address 09: Cent. Elect.
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00140
Shop #: WSC 06402
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags
Part No: 6Q0 909 605 AD
Component: 03 AIRBAG VW5 0010
Coding: 12339
Shop #: WSC 06401
Address 17: Instruments
Part No: 6L0 920 823 C
Component: KOMBIINSTRUMENT VDO V01
Coding: 00102
Shop #: WSC 00000
Address 19: CAN Gateway
Part No: 6N0 909 901
Component: 0069 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
Address 44: Steering Assist
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10111
Shop #: WSC 06402
Address 46: Central Conv.
Part No: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00018
Shop #: WSC 06402
Address 56: Radio
Part No: 6L0 035 186 C
Component: seat s04 GRO 5 37
Coding: 00401
Shop #: WSC 06402
End
