que sera?
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 JE HW: 028 101 272 6
Component: R4 2,0L EDC 000CG 8247
Revision: --H01--- Serial number:
Coding: 0000076
Shop #: WSC 06435 000 00000
1 Fault Found
006480 - Radiator Fan (V7): Movement Restricted / Jammed
P1950 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Mileage: 138897 km
Time Indication: 0
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000000
Temperature: 73.8°C
Duty Cycle: 30.6 %
Readiness: 0 0 1 0 1
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 00001
Shop #: WSC 00035
3 Faults Found
01496 - Bulb for Fog-Lamps; Left (L22)
30-00 - Open or Short to Plus
01500 - Bulb for Fog-Lamps; Right (L23)
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
acontece que as luzes de nevoeiro trazeiras não funcionam (já verifiquei as lámpadas) e quando ligo as luzes de nevoeiro traseiras (tando os minimos ligados) liga-me os médios.
o que será?
Coding: 0000076
1 Fault Found
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 138897 km
Time Indication: 0
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000000
Temperature: 73.8°C
Duty Cycle: 30.6 %
Coding: 00001
Shop #: WSC 00035
3 Faults Found
35-00 - -
o que será?
