Depois de fazer um diagnostico a bicha derivado a luz dos travoes acender e logo de seguida a de abs desligando 2/3 segundos depois e nao encontrei nada :roll: deduzo que seja do alternador :S porque anda a fazer um barulho um bocadinho estranho mas nao acusou nada no vagcom mas encontrei um erro no alarme se alguem pudesse ajudar
Aqui fica :
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Controller: 038 906 018 S
Component: 1,9l R4 EDC 00SG 1621
Coding: 00002
Shop #: WSC 06325
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 D
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 860 E
Component: B5-KOMBIINSTR. VDO D09
Coding: 00040
Shop #: WSC 70076
IMMO-IDENTNR: AUZ7Z0V0221782
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 E
Component: ZV-Pumpe D03
Coding: 00032
Shop #: WSC 65535
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
End -------------------------------------------------------
Aqui fica :
Coding: 00002
Shop #: WSC 06325
1 Fault Found:
P1570 - 35-00 - -
Readiness: N/A
Coding: 0273004281
Shop #: BB 24548
Coding: 00040
Shop #: WSC 70076
1 Fault Found:
01176 - Key
No Faults Found
Coding: 00032
Shop #: WSC 65535
8 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
