sumodos300
Utilizador Banido
boas
no carro do meu pai (golf 4tdi 110) apareceu isto:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
e na net diz isto:
Possible Symptoms
* Difficulties with starting a cold engine.
* Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
* RPM at idle is irregular.
* With all engine temperatures seldom idle rpm will vary between 900 - 1000 rpm.
* With engine warm (90 °C) the engine temperature suddenly drops (70 °C) and slowly comes back to 90 °C.
* Bad acceleration during warming up.
Diesel: an indication is extreme long time burning time of the glow indication light.
e realmnte acontece k dou uma volta e ale chega aos 90º e passado um bukado olho po ponteiro da temperatura e desceu tipo pa meio
alguem sabe od fika o tal g2???
tks
e na net diz isto:
Possible Symptoms
tks
