Hoje de manhã fiz um Autoscan á minha viatura visto ter ocurrido um problema na alteração re rpm como expliquei num topico anterior, e o resultado são os seguintes erros. Opinem para possiveis soluções :roll:
Address 56: Radio Labels: None
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H53 0060
Coding: 0001001
Shop #: WSC 06435
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
Freeze Frame:
Bin. Bits: 10
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 7
Reset counter: 220
Mileage: 121080 km
Time Indication: 0
Date: 2009.11.15
Time: 07:45:14
Address 17: Instruments Labels: 8P0-920-xxx-17.LBL
Part No SW: 8P0 920 930 F HW: 8P0 920 930 F
Component: KOMBIINSTR. VDO H25 0110
Coding: 0004103
Shop #: WSC 00066
1 Fault Found:
01298 - Instrument Cluster Lamp Test
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Address 01: Engine Labels: None
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Coding: 0000072
Shop #: WSC 00066
1 Fault Found:
18051 - Please check DTC Memory of Electric Load Controller
P1643 - 000 - - - Intermittent
Freeze Frame:
RPM: 1008 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 11000000
Load: 46.7 %
(no units): 1.0
Readiness: 0 0 0 0 0
Coding: 0001001
Shop #: WSC 06435
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
Freeze Frame:
Bin. Bits: 10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 220
Mileage: 121080 km
Time Indication: 0
Date: 2009.11.15
Time: 07:45:14
Coding: 0004103
Shop #: WSC 00066
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Coding: 0000072
Shop #: WSC 00066
1 Fault Found:
Freeze Frame:
RPM: 1008 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 11000000
Load: 46.7 %
(no units): 1.0
