problemas no meu argolas
tenho um A4 motor awx 1.9 tdi 130cv e ja a faltar a potencia no motor fiz um scan e deu-me estes erros
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 JQ
Component: 1,9l R4 EDC 0000SG 1570
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E23A171975 AUZ6Z0B0241594
2 Faults Found:
16485 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 35-00 - -
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 J
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
No fault code found.
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63351
1 Fault Found:
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 00001
Shop #: WSC 34495
Address 37 -------------------------------------------------------
Controller: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0008
1 Fault Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AR
Component: Komfortgerát T85 1310
Coding: 07008
Shop #: WSC 63351
1 Fault Found:
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D08
Coding: 00060
Shop #: WSC 63351
já trocei o medidor de massa de ar e a válvula N75 mas o problema continua alguem me pode ajudar?
Obrigado e abraços a todos
tenta ver os tubos de vácuo se estão todos bons se não está nenhum roto, o que é que ele faz mesmo? faz safe mode?
ja levei o carro ao meu mecanico para ver se estava tudo bem com os tubos ele disse que sim.
o carro anda bem ate aos 140km no max 160km e depois morre e puxa fixe ate as 3000rpm quando deixa de puxar se largar logo o acelarador ele nao prende se manter a acelaraçao deita algum fumo preto e morre eu desligo e ligo e ele fixe bom por mais um bocado
HugoDuarte disse:
Está a fazer Safe-Mode.
Pelos ERROS, ou MAF ou Turbo.
neljoe disse:
a maf é nova mas vou ver as vezes pode ter vindo com defento de fabrica. o turbo vai ser a ultima coisa a ser vista ja que tb é o mais caro para ser reparado
HugoDuarte disse:
É só descarbonizar, vê se os tubos de vácuo e ou os da coluna dar estão bons, depois parte para a descarbonização do turbo, viste que a MAF é nova, só pode ser isso.
DreamRings disse:
problema resolvido levou novos aneis de fixaçao dos tubos do intercoler e admiçao de ar, um filtro de ar k&n e agora é sempre a galgar. ja nao entra em safe mode como ja posso andar na AE a mais de 140km
obrigado a todos pela a ajuda
