Boa tarde,
Ando aqui com um problema na minha carrinha que não consigo resolver. é o seguinte:
Quando ligo as luzes, médios e mínimos, ficam acessas mas o 3ºstop fica a acender e apagar ao mesmo tempo que as luzes parece que também piscam.
Ja liguei o vagcom e aparecem me estes erros:
VCDS Version: Release 11.11.0
Data version: 20111111
Tuesday,10,December,2013,10:53:51:37412
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E72A237998 Mileage: 163900km/101842miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 FP
Component: 1,9l R4 EDC 0000SG 1538
Coding: 00002
Shop #: WSC 63351
VCID: 6AD1B30C1664F6E
WAUZZZ8E72A237998 AUZ6Z0B0020194
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 00000
VCID: E5CB40307F7A596
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 A
Component: A4 Klimaautomat 0912
Coding: 00000
Shop #: WSC 63351
VCID: 1F4792D89DA6C36
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 C
Component: int. Lastmodul RDW 0203
Coding: 00001
Shop #: WSC 63351
VCID: 32616B6CFE347EE
1 Fault Found:
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 5001
Coding: 0011602
Shop #: WSC 31780 142 18076
VCID: F4ED2D7494A0B0E
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00002
Shop #: WSC 63351
VCID: 3669577C125C62E
1 Fault Found:
01044 - Control Module Incorrectly Coded
35-00 - -
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 00000
Shop #: WSC 00001
VCID: 28558904C8E804E
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 06976
Shop #: WSC 63351
VCID: 73EFAE6841AE376
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
3 Faults Found:
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
01562 - Right Rear Door
59-00 - Can't Unlock
61-00 - Won't De-Safe
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186
Component: concert II GRO 0007
Coding: 00001
Shop #: WSC 63351
VCID: E4CD5D34744020E
Ja procurei se ja alguem teve este problema mas nada, e precisava de uma ajudita que isto parece me uma arvore de natal.
69 75 76 77
Coding: 00002
Shop #: WSC 63351
Coding: 04255
Shop #: WSC 00000
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
Coding: 0011602
Coding: 00002
Shop #: WSC 63351
1 Fault Found:
35-00 - -
Coding: 00000
Shop #: WSC 00001
Coding: 06976
Shop #: WSC 63351
3 Faults Found:
Coding: 00001
Shop #: WSC 63351
