Primeiro Scan com VAGCOM
Boas, comprei a primeira vez o vagcom e venho agora de fazer um auto-scan ao meu b6 e os resultados nao foram muito animadores mas se poderem ajudar com alguma coisa agradeco, vou andar a googlar um pouco quando chegar a casa mas deixo ja a lista que me apareceu caso algum conheca algum codico destes mas principalmente o do turbo esta me a chatear um pouco:
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Friday,13,November,2015,12:24:35:62939
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E14A032065 Mileage: 159000km/98798miles
Part No SW: 8E0 909 518 AN HW: 8E0 909 018 A
Component: 1.8L R4/5VT 0002
Coding: 0011511
Shop #: WSC 63351 000 00000
VCID: 7CF7127B3C1EBCFEC8B-5000
9 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 001 -
16683 - Boost Pressure Regulation
P0299 - 002 - Control Range Not Reached - Intermittent
16891 - Idle Control System RPM
P0507 - 001 - Higher than Expected.
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 001 - System too Lean - Intermittent
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent
16685 - Cylinder 1
P0301 - 008 - Misfire Detected - Intermittent
16686 - Cylinder 2
P0302 - 008 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
Readiness: 0000 0101
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04475
Shop #: WSC 06435
VCID: E5C1D71F7F949D36875-5072
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63351
VCID: 60CF460BE0B6781EF43-5000
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul NDL 0305
Coding: 00002
Shop #: WSC 00186
VCID: 3467FA5B04CEB4BE40B-4A3A
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 3002
Coding: 0010602
VCID: 3663C05342B2A6AE7EF-5072
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00011
Shop #: WSC 63351
VCID: 3663C05312B2A6AE7EF-4A3A
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00100
Shop #: WSC 00000
VCID: 2D51EF3FE7E4E5760F5-5072
WAUZZZ8E14A032065 AUZ6Z0C0115198
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BA
Component: Komfortgerát TA7 1310
Coding: 06720
Shop #: WSC 63351
VCID: 71E9334F3B5CC1966BD-4A9C
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0003
4 Faults Found:
01561 - Rear Left Door
61-10 - Won't De-Safe - Intermittent
01562 - Rear Right Door
59-10 - Can't Unlock - Intermittent
00955 - Key 1
Obrigado se alguem poder ajudar.
então agora para começar, apagas todos os erros, pois podem ser erros antigos, e que não existem mais, depois apos teres andado uns kilometros com o carro, voltas a passar o VAG..
Boas, o ano passado quando comprei o carro mandei fazer uma revisao e apagaram me os erros todos e ha uma semana atras ao tirar os bancos do carro para fazer uma limpeza a fundo, desliguei a bateria e quando a liguei a luz do motor e a do esp ficaram ligadas e depois desapareceram e hoje sai com o carro e notei que ele nao esta a puxar muito bem, principalmente quando estou numa subida nota-se que tem mais dificuldade em desenvolver mas nota se mesmo que parece estar preso, alem de ele ter sempre tremido ao relantim e no para arranca comecar a acelerar sozinho ate as 3000 rpm mas isso ja se torna normal ...
ok.. mas faz la 1º o que eu disse acima, e depois de andares uns bons kilometros, +/- 100km
Boas, ja eliminei os erros e fiz 300Kms quase hoje e voltei a fazer o teste do Vag Com e eis o resultado:
Sunday,15,November,2015,15:04:43:62939
67 69 75 76 77
VIN: WAUZZZ8E14A032065 Mileage: 159610km/99177miles
Coding: 0011511
VCID: 7CF7127B3C1EBCFEC8B-5072
6 Faults Found:
P1297 - 001 -
P0300 - 002 - - Intermittent
16685 - Cylinder 1
P0301 - 002 - Misfire Detected - Intermittent
16686 - Cylinder 2
P0302 - 002 - Misfire Detected - Intermittent
Readiness: 0000 0000
Coding: 04475
Shop #: WSC 06435
VCID: E5C1D71F7F949D36875-5000
Coding: 00000
Shop #: WSC 63351
VCID: 60CF460BE0B6781EF43-5072
Coding: 00002
Shop #: WSC 00186
Coding: 0010602
VCID: 3663C05342B2A6AE7EF-5000
Coding: 00011
Shop #: WSC 63351
Coding: 00100
Shop #: WSC 00000
VCID: 2D51EF3FE7E4E5760F5-5000
Coding: 06720
Shop #: WSC 63351
2 Faults Found:
Alguem me sabe dizer se ha alguma coisa de grave mesmo ? eu sinto alguma perda de potencia que se tem intensificado ao longo do tempo...
Obrigado desde ja.
67 69 75 76 77
Coding: 0011511
6 Faults Found:
P1297 - 001 -
16685 - Cylinder 1
16686 - Cylinder 2
Coding: 04475
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
Coding: 00002
Shop #: WSC 00186
Coding: 0010602
Coding: 00011
Shop #: WSC 63351
Coding: 00100
Shop #: WSC 00000
Coding: 06720
Shop #: WSC 63351
2 Faults Found:
Obrigado desde ja.
estes foram os erros que voltaram apos os teres apagado certo?
tens fuga entre o turbo e a borboleta de admissão, o próprio erro diz para veres o estado da DV, procura também por fugas nos tubos, os "misfire" pode dever-se á esta fuga que tens, por isso convém primeiro resolveres as fugas..
muito bem, vou ver se consigo fazer alguma coisa esta semana, eu vi no youtube uma maneira facil de descobrir as fugas, ele inseria fumo com uma maquina e depois era so esperar que saia o fumo mas eu nao sei fazer isso, achas que se consegue descobrir essas fugas apenas ao tocar nelas ?
começa por ver se tens algum tubo solto, ou com rasgão, abraçadeiras soltas uniões partidas, começa por analisar tudo a volta da DV, com ela também incluída.. se não detetares nada, existem uns kits de ar muito bons para detetar fugas, ou então vais a uma oficina para que te vejam isso..
