Não consegui env por imagem...
Não sei se se vai entender
VCDS
Windows Based VAGNAS Emulator
VCDS Version: Release 805.0 Data version: 20080730
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000
Self-Diagnosis log
Friday, 16,January,2009, 11 :23:46:21461
VIN: License Plate:
Mileage: Repair Order:
Chassis Type: 8l - Audi A3/S3
Scan: 01 020308 15 16 17223537455556577576
Mileage: 119190km174061miles
Address 01: Engine labels: None
Part No: 8NO 906 018
Component: 1.8l R4 5VT 0003
Coding: 05610 Shop#: WSC 06313
3 Faults Found:
18056 - Powertrain Data Bus: Failure
P1648 - 35-10 - - - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes labels: Redir Fail!
Part No: 8NO 907 379 A
Component: ABS/EDS 20 IE CAN V001 Coding: 13504
Shop #: WSC 06435
2 Faults Found:
01324 - Control Module for Ali Wheel Drive (J492)
49-00 - No Communications
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 08: Auto HVAC labels: 8l0-820-043-2D.lbl
Part No: 810 820 043 D Y
Component: A3 KLlMAVOlLAUTOMAT_D75 -v¬Coding: 03140
Shop #: WSC 06313
No fault code found.
VCDS Self-Diagnosis Log
Friday, 16,January,2009, 11 :23:46:21461 Page2
VIN: License Plate:
Address 17: Instruments Labels: 8LO-919-xxx-17.lbl
Part No: 8LO 919 880 FX
Component: AB-KOMBIINSTR. VDO D06 Coding: 04142
Shop #: WSC 00058
Part No: IMMO
Component: IDENTNR: AUZ7Z0Y1363885 IMMO-IDENTNR: AUZ7Z0Y1363885
Address 22: AWD Labels: None
Part No: 02D 525 554
Component: HALDEX LSC ECC 000900 Coding: 00000
Shop #: WSC 00000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks Labels: 8DG-862-257.lbl
Part No: 8LO 862 257 G
Component: ZV-Pumpe, DWA, Funk D11 Coding: 13130
Shop #: WSC 06313
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
00991 - Interior Lights 28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
VCOS
Self-Oiagnosis Log Friday,16,January,2009,11 :23:46:21461 Page3
VIN: License Plate:
-------------------------------------------------------------------------------------------------------------------------------------------------Address 45: Inter. Monitor Labels: 4BO-951-173.lbl
Par! No: 4BO 951 173
Component: Innenraumueberw. 003 Coding: 00001
Shop#: WSC 06313
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Par! No: 4BO 907 357
Component: LEUCHTWEITEREGLER 0003 Coding: 00002
Shop #: WSC 06313
End --------------------------------------------------------------------------------------------------------------------------------------------
Se calhar não tem nada a ver...lol
