Bom dia! Ontem no meu Audi A3 SP 2008 1.9 tdi acendeu no quadrante a luz amarela da emissão de gases. Já fiz uma condução em 4ª velocidade cerca de 15 minutos e não apagou-se. Será o filtro de particulas. meti-lhe a Vag-com e reportou estes erros:
Part No SW: 03G 906 021 RE HW: 03G 906 021 AB
Component: R4 1,9L EDC 000SG 1955
Revision: --H07--- Serial number: AUX7Z0H1FNL0RB
Coding: 0000071
Shop #: WSC 06325 000 00000
3 Faults Found:
005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
P161B - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 3
Fault Frequency: 2
Mileage: 57096 km
Time Indication: 0
Date: 2011.01.24
Time: 23:03:21
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00000100
Temperature: 23.4°C
Bin. Bits: 00110000
005658 - Glowplug for Cylinder 1 (Q10): Open Circuit
P161A - 000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Mileage: 57096 km
Time Indication: 0
Date: 2011.01.24
Time: 23:04:18
Freeze Frame:
RPM: 1638 /min
Speed: 14.0 km/h
Load: 49.8 %
Voltage: 14.44 V
Bin. Bits: 00000000
Temperature: 25.2°C
Bin. Bits: 10110000
001139 - Exhaust Pressure Sensor 1 (G450): Signal too High
P0473 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 64
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Mileage: 20 km
Temperature: 66.0°C
Absolute Pres.: 1774.8 mbar
Readiness: 1 1 0 0 0
____________________________________
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: KlimavollautomatH19 0430
Revision: 251666 Serial number: 8P0820043AG
Shop #: WSC 00000 000 00000
1 Fault Found:
00796 - Fan for Interior Temp Sensor (V42)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 23
Reset counter: 232
Mileage: 52586 km
Time Indication: 0
Date: 2010.10.13
Time: 17:34:20
Freeze Frame:
Voltage: 12.50 V
Temperature: 37.0°C
_____________________________________--
Alguém sabe o que será?
Obrigado.
Coding: 0000071
3 Faults Found:
P161B - 000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Mileage: 57096 km
Time Indication: 0
Date: 2011.01.24
Time: 23:03:21
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00000100
Temperature: 23.4°C
Bin. Bits: 00110000
P161A - 000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Mileage: 57096 km
Time Indication: 0
Date: 2011.01.24
Time: 23:04:18
Freeze Frame:
RPM: 1638 /min
Speed: 14.0 km/h
Load: 49.8 %
Voltage: 14.44 V
Bin. Bits: 00000000
Temperature: 25.2°C
Bin. Bits: 10110000
P0473 - 000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 64
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Mileage: 20 km
Temperature: 66.0°C
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 232
Mileage: 52586 km
Time Indication: 0
Date: 2010.10.13
Time: 17:34:20
Freeze Frame:
Voltage: 12.50 V
Temperature: 37.0°C
Obrigado.
