"limitador velocidade"
Quando se passa dos 120KM/h apita.....
basta mudar isto no painel instrumentos....
e é arabia saudita penso eu..
Recode for warning lamps:
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active
Look at the third digit in the coding (Market version):
1 - "EU" 24 hour clock (may result in odometer in km in 2002+ clusters)
2 - "USA" 12 hour clock
3 - "Canada" 12 hour clock (may result in odometer in km in 2002+ clusters)
"The third digit in the code is the country code. The codes are:
4 - "UK" 24 hour clock (should result in odometer in miles)
5 - Japan
6 - Saudi Arabia
7 - Australia
Look at the fourth digit in the coding (Cylinders):
3 - No Service Interval (2002+ models)
4 - 4-cylinder (1999-2001 models)
6 - 6-cylinder (1999-2001 models)
Look at the fifth digit in the coding (Distance impulse multiplier):
2 - 3538
4 - 3648 (some 2002+ models)
So, if you want to have Seatbelt warning and washer fluid warning only in a 2001 Canadian 6-cylinder vehicle, (add 00+02+04 = 06),3,6,2 = 06362.
fonte tirada de outro forum.... :p
pois ainda nao expermentei pelo cabo...... mas pelo quadrante tb nao sei como se faz...?!! é um A3 8L 2001
na minha,como tem relogio analogico no quadrante,no botão do relogio,que fica do lado esquerdo,precionei durande 5 sec,que apareceu uma luz de aviso ( KMh/2)... apartir dai quando passa os 120,bip!!!..até xega a ser irritante...
Hay dos avisos:
1º Permanente, que es el que tu tienes activado. AFuncionamiento.
-Antes de encender el coche, dejas pulsado el boton del reseteo de kilometros, se enciende la pantalla de cuenta kilometros
-Mantienes pulsado el de comprobacion de averias del FIS y se enciende el limitador
-Baja o sube la velocidad a la que quieres que pite, 140, 150, .....o 350 si no quieres que pite nunca
-Esa velocidad se queda guardada y ya puedes meter la llave y arrancar
2º El de viajes.
-Se conecta pulsando el boton de comprobacion de fallos(o el otro, no me acuerdo) cuando vas a una determinada velocidad
-se guarda esa velocidad como avisador, y cada vez que pases de ella pitará.
-Se desconectara cuando dejes el coche parado, o en marcha si vas a esa misma velocidad le vuelves a dar al boton, te apararece tachado indicando que lo has desconectado.
Não traduzo pq a fonte é o fórum dos nossos amigos da ASI.
