Boas Tardes,
Amigos tenho andado sumido mas finalmente tenho 1 tempo pra passar por aki, e logo para chatear...lol
É o seguinte fiz 1 Scan a minha carrinha e deu-me 5 erros mas como eu sou pra lá de lerdo nao sei o que significa ja fiz Copy e foi ao tradutor mas nada feito. Se alguem me poder ajudar so para saber se ta tudo ok nao va tar algo mal com a Bicha. lol
Desde ja Obrigado a todos
[size=10pt]
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Controller: 038 906 018 S
Component: 1,9l R4 EDC 00SG 1630
Coding: 00002
Shop #: WSC 06325
2 Faults Found:
00519 - Intake Manifold Pressure Sensor (G71)
28-00 - Short to B+
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 D
Coding: 04143
Shop #: WSC 06325
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 861 A
Component: B5-KOMBIINSTR. VDO D09
Coding: 00040
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0W0527140
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 K
Component: ZV-Pumpe, Funk D06
Coding: 12896
Shop #: WSC 06325
3 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01389 - Tailgate Open Switch (F124)
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to B+
End -------------------------------------------------------[/size]
[size=10pt]
Coding: 00002
Shop #: WSC 06325
2 Faults Found:
28-00 - Short to B+
P1570 - 35-00 - -
Readiness: N/A
Coding: 0273004281
Shop #: BB 24548
Coding: 04143
Shop #: WSC 06325
Coding: 00040
Shop #: WSC 00000
1 Fault Found:
01176 - Key
No Faults Found
Coding: 12896
Shop #: WSC 06325
3 Faults Found:
35-00 - -
28-00 - Short to B+
