Olá
ontem tive pela 1º vez a experimentar o VAG-Com e encontrei estes erros. Alguem me sabe dizer o que são e se são importantes.
Fault codes
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Controller: 8E0 907 401
Component: 2.5L V6 TDI G000SG 0006
Coding: 02012
Shop #: WSC 63351
00004059 130 106JC 106JCV77709146192
1 Fault Found:
01375 - Valves for Engine Mounting: Stage 1
38-10 - Output won't Switch or Short to B+ - Intermittent
Readiness: N/A
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 J
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 00000
Shop #: WSC 00001
WAUZZZ8E32A209325 AUZ6Z0A0351274
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
49-10 - No Communications - Intermittent
Address 37 -------------------------------------------------------
Controller: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0007
1 Fault Found:
37-10 - Faulty - Intermittent
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AE
Component: Komfortgerát T01 0315
Coding: 06976
Shop #: WSC 63351
1 Fault Found:
01561 - Left Rear Door
61-00 - Won't De-Safe
End -------------------------------------------------------
Fault codes
Coding: 02012
Shop #: WSC 63351
1 Fault Found:
Readiness: N/A
Coding: 00000
Shop #: WSC 00001
1 Fault Found:
1 Fault Found:
Coding: 06976
Shop #: WSC 63351
1 Fault Found:
