Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Controller: 038 906 019 BR
Component: 1,9l R4 EDC 0000SG 1064
Coding: 00002
Shop #: WSC 06325
2 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AH
Component: ABS/ASR 5.3 FRONT D10
Coding: 00012
Shop #: WSC 06435
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Address 15 -------------------------------------------------------
Controller: 8D0 959 655 J
Component: Airbag Front+Seite 1001
Coding: 01106
Shop #: WSC 06325
No fault code found.
Address 17 -------------------------------------------------------
Controller: 8D0 920 931
Component: B5-KOMBIINSTR. VDO D11
Coding: 02060
Shop #: WSC 00050
���������������� AUZ7Z0Y1392811
3 Faults Found:
01176 - Key
07-10 - Signal to Low - Intermittent
01300 - Control Module for Navigation with CD-Rom (J401)
49-00 - No Communications
01311 - Information Data Bus
37-10 - Faulty - Intermittent
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14913
Shop #: WSC 06435
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 E
Component: Radio 0001
Coding: 00201
Shop #: WSC 06435
1 Fault Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
End -------------------------------------------------------
Coding: 00002
Shop #: WSC 06325
2 Faults Found:
P1570 - 35-00 - -
Readiness: N/A
Coding: 00012
Shop #: WSC 06435
1 Fault Found:
Controller:
Coding: 01106
Shop #: WSC 06325
Coding: 02060
Shop #: WSC 00050
3 Faults Found:
01176 - Key
No Faults Found
Coding: 14913
Shop #: WSC 06435
Coding: 00201
Shop #: WSC 06435
1 Fault Found:
