Olá e boas a todos , hoje fui ligar o carro ao cabo do user FANTASMA ao qual quero desde ja agradecer muito a paciencia e o tempo perdido , muito obrigado pessoa 7 estrelas .
o carro deu uns erros ao qual gostaria de pedir ajuda para poder interpretar melhor visto eu ser um noob nestas andanças .
VAG-COM Version: Release 607.3-UD
Sunday,04,April,2010,17:30:23
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 01: Engine
Part No: 038 906 018 A
Component: 1.9l R4 EDC 00SG 1001
Coding: 00002
Shop #: WSC 06313
1 Fault Found:
00550 - Start of Injection Regulation
17-00 - Control Difference
Readiness: N/A
Address 03: ABS Brakes
Part No: 1J0 907 379
Component: ABS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC
Part No: 8L0 820 043 B
Component: A3 KLIMAVOLLAUTOMAT_D73
Coding: 03143
Shop #: WSC 78298
Address 15: Airbags
Part No: 1J0 909 601 A
Component: AIRBAG VW3 V01
Coding: 00065
Shop #: WSC 06313
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments
Part No: 8L0 919 880
Component: AB-KOMBIINSTR. VDO D14
Coding: 04040
Shop #: WSC 00000
Part No: IMMO
Component: IDENTNR: AUZ7Z0T0042238
IMMO-IDENTNR: AUZ7Z0T0042238
Address 35: Centr. Locks
Part No: 8LO 862 257 E
Component: ZV-Pumpe
Coding: 00000
Shop #: WSC 65535
12 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm; Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm; Open
01389 - Tailgate Open Switch (F124)
End --------------------------------------------------------------------------------------------------
um abraço forte e boas curvas a todosray:
Address 01: Engine
Coding: 00002
Shop #: WSC 06313
1 Fault Found:
Readiness: N/A
Coding: 03604
Shop #: WSC 06435
Coding: 03143
Shop #: WSC 78298
Address 15: Airbags
Coding: 00065
Shop #: WSC 06313
1 Fault Found:
Coding: 04040
Shop #: WSC 00000
Part No: IMMO
Component: ZV-Pumpe
Coding: 00000
Shop #: WSC 65535
12 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
