Boas pessoal,
Fiz um log a um A3 8P e tem estes erros:
Address 03: ABS Brakes (J104) Part No SW: 1K0 907 379 BE
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermitten
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
Component: KlimavollautomatH09 0170
Revision: 000113 Serial number: 8P0820043BN
Shop #: WSC 00000 000 00000
VCID: 79464083FB3E512BFD-802C
1 Fault Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Address 09: Cent. Elect. (J519) Part No SW: 8P0 907 063 G
1 Fault Found:
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Address 37: Navigation Part No SW: 8P0 035 193 G
2 Faults Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 1
02444 - Disk Drive Load / Eject Malfunction
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Andei a pesquisar e penso que o erro do ABS e do Klima (08) se terão devido a falha na bateria. Os restantes se alguém puder ajudar agradecia, sendo que o DVD de navegação funciona. Não tentei apagar os erros para ver se eram permanentes, queria acima de tudo entender o que os terá originado.
Alguém sabe para que serve este módulo - Address 61: Battery Regul. (J840), Part No SW: 8P0 907 534 HW: 1K0 907 951, Component: Batt.regelung.
Agradeço a quem puder e souber ajudar.
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
2 Faults Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
