Erros vag-com
Boas
Hoje apeteceu-me ligar o pc ao carro e fazer um auto-scan, so para ver se estava tudo ok, mas deu-me alguns erros...
Peço agora a vossa ajuda para ver que erros são e como resolve-los :wink:
Address 08 -------------------------------------------------------
Controller: 8E0 820 043
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
Address 37 -------------------------------------------------------
Controller: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0050
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 07008
Shop #: WSC 63351
1 Fault Found:
01331 - Door Control Module: Driver Side (J386)
80-10 - Single-Wire Operation - Intermittent
:wink:
Aqui tens o teu 3º ERRO:
Possible Causes
Control Module housing leaky > Control Module wet
Wiring from/to Control Module faulty
Possible Solutions
Check/Clean Wiring from/to Control Module
Replace Control Module
Special Notes
This fault is NOT to be ignored when found in a major and/or critical system (Airbag, ABS etc.).
When stored in other systems (Radio etc.) the general suggestion is to ignore it unless you notice functional limitations.
Audi Airbag 6 & 7
Problem: A fault of the acceleration sensor may result in the above fault.
Solution: Replace Airbag control module and both acceleration sensors.
Audi Airbag 8
Problem: Due to under voltage the control module does not complete it's self test successfully.
Solution: Replace Airbag control module and install a under voltage protection relay for it.
Certain older TDI ECUs which have a vacuum line going to them
Problem: Vacuum line broken, either before ECU or inside ECU.
Solution: Inspect and repair vacuum lines to ECU and inside ECU.
:roll:
O 1º e º 2º erro também já apareceram na minha viatura:
Apaguei os erros e até à data não voltaram a aparecer...faz o mesmo :wink:
00532 - Módulo de controlo do motor - Fusível, alternador, bateria, tomada de corrente com a ignição desligada, rele de controlo do motor, cablagem.
65535 - Modulo de controlo do motor defeituoso. Causa provavel - modulo de controlo do motor
Autodata 2004
Quanto aos erros intermitentes não darão dores de cabeça quando apagados, visto q podem ter acontecido aquando de alguma intervenção em sensores do motor com a ignição ligada.
O q será um problema é o modulo de controlo. este modulo 37 e do sistema de navegação. tb não ficas na estrada por causa disto.
Thunder disse:
Obrigado a todos pela rapida ajuda :wink:
Bem ja estou mais descansado, quando vi aqueles erros todos assustei-me um pouco. Sendo assim será apenas apagar os erros, e como faço isso?lool
Em relação ao modulo 37, este nao me faz nenhuma diferença, a caixa que le os cd's DX Navigation que se situa na mala está mesmo marada, mas isso eu ja sabia, alem do mais eu nao uso o gps. Ja pensei em arranjar, mas estou a pensar em colocar o RNS-E :D
Abraços :wink:
Boas
Para apagar os errros fazes da mesma maneira como fizeste pa ver os erros. depos aparece uma opção q diz limpar erros (em portugues ou ingles, dependendo do sotware).
