Erros Vag-com - airbag 01794 ajuda!!!
Boas.
Cum a ajuda do nosso amigo estebescaneca, que fez o diagnóstico ao meu argolas, deixo aqui o seu resultado.
Desde já o muito obrigado ao user estebescaneca, pela sua disponibilidade.
Monday,30,March,2009,14:48:35:26365
VCDS Version: Beta 812.4
Data version: 20090214
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage: 124630km/77441miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC G000SG 4910
Coding: 00002
Shop #: WSC 63251
WAUZZZ8EX4A034705 AUZ6Z0C0113736
1 Fault Found
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04255
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63251
1 Fault Found
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 01011
Shop #: WSC 63251
1 Fault Found
35-00 - -
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 3002
Coding: 0010602
Shop #: WSC 63251 000 00000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 03042
Shop #: WSC 63251
3 Faults Found
01303 - Telephone Transceiver (R36)
49-10 - No Communications - Intermittent
01304 - Radio
49-00 - No Communications
35-00 - -
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00000
Shop #: WSC 00001
Part No: 34705
Component: AUZ6Z0C0113736
4 Faults Found
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01316 - ABS Control Module
01304 - Radio
01300 - Control Module for Navigation with CD-Rom (J401)
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0040
1 Fault Found
00862 - Antenna for GPS Navigation (R50/R52)
36-00 - Open Circuit
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AR
Component: Komfortgerát T85 1310
Coding: 07012
Shop #: WSC 63251
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0003
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0003
4 Faults Found
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
01705 - Selection Switch for Mirror-Adjust (E4
27-10 - Implausible Signal - Intermittent
01331 - Door Control Module; Driver Side (J386)
80-10 - Single-Wire Operation - Intermittent
01559 - Drivers Door
59-10 - Can't Unlock - Intermittent
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63251
Address 77: Telephone Labels: None
Part No: 8E0 862 333 A
Component: Telefon Nokia3 0303
Coding: 0005132
1 Fault Found
01304 - Radio
004 - No Signal/Communication
Re: Erros Vag-com
Boas.
Sim, ainda indica, isto passados uns 10 minutos com o carro a trabalhar.
estive a ler umas coisas e tudo indica que terás de configurar isso por vag da seguinte maneira:
Audi A4 (8E) 08-HVAC
10-Adaptation, Channel 081: Vehicle Data Learning
To start the process for vehicle data (VIN) learning, enter/save 26467 as new value.
-Audi A4 (8E) 15-Airbag
To start the process for vehicle data (VIN) learning, enter/save 02905 as new value.
-Audi A4 (8E) 16-Steering Wheel
To start the process for vehicle data (VIN) learning, enter/save 00111 as new value.
basicamente é aceder aos modulos que te estão a dar o erro 01794 e fazer o que está descrito acima.
Segundo li, esse erro está associado ao facto de terem mudado o módulo do airbag e depois não o configuraram.
Ou isso ou tens um problema no painel de instrumentos, que pelos vistos é muito comum nas B6 e que só se resolve colocando um novo =(
mas estou mais inclinado que alguem deve ter dado um toquezito e lá disparou um airbag, e tiveram de mudar o módulo e não programaram isso.
mas deixa vir os experts...
Re: Erros Vag-com
Boas...
Espero que não seja nada de grave.
Penso que os outros erros, portas, devem ser de eu ter tirado o fusivel e ter ligado a ignição.
Re: Erros Vag-com
edita o titulo do primeiro post para erros vag com - airbag 01794 ajuda!!!
assim a malta responde com mais facilidade, digo eu...
Boas...
Neste print não tem os erros do airbag, se ainda tiveres o 1º print, coloca-o aqui...
ng esta a ajudar....
um dia que queiras combinamos para tornar a colocar isso no vag e fazer umas coisas como já postei aqui para ver se elimino esse erro do airbag =)
Boas...
Aqui fica o ultimo scan feito ao meu argolas.
Thursday,15,July,2010,14:24:18:13314
VCDS Version: Release 908.0
Data version: 20090911
69 75 76 77
Mileage: 124900km/77609miles
Coding: 00002
Shop #: WSC 63251
Coding: 04255
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63251
1 Fault Found:
35-00 - -
Coding: 01011
Shop #: WSC 63251
1 Fault Found:
35-00 - -
Coding: 0010602
2 Faults Found:
00474 - Control Module for Immobilizer
004 - No Signal/Communication - Intermittent
000 - - - Intermittent
Coding: 03042
Shop #: WSC 63251
2 Faults Found:
01304 - Radio
35-00 - -
Coding: 00000
Shop #: WSC 00001
Part No: 34705
2 Faults Found:
01304 - Radio
1 Fault Found:
Coding: 07012
Shop #: WSC 63251
Part No: 8E1959801B
Part No: 8E1959802B
Coding: 00060
Shop #: WSC 63251
Coding: 0005132
1 Fault Found:
01304 - Radio
agora que tens vag, tens de resolver o problema 01794, os outros são pequenas coisas que depois vais vendo, mas o erro de aairbag que te aparece no carro mais ou menos 10minutos após ligares advém desse erro.
Re: Erros Vag-com
faz o que disse aqui para ver se consegues configurar o modulo...
Boas...
com essas dicas o erro do airbag já não aparece e a luz deixou de acender.
Agora tenho tambem de ver este:
