Boas, ontem estive a fazer um scan com o Vag e deu-me os seguintes erros, como não sou especialista no assunto, se poderem ajudar agradecia..
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000005661437
Coding: 01884F019614100000160000160000000008FE175C0100
Shop #: WSC 06314 000 08192
Part No: 8P1 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
1 Fault Found
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 45
Mileage: 43066 km
Time Indication: 0
Date: 2009.04.06
Time: 18:36:00
Freeze Frame:
ON
Voltage: 14.10 V
ON
ON
OFF
OFF
OFF
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 G HW: 1K0 907 951
Component: J533__Gateway H10 0140
Revision: H10 Serial number: 300010640186ED
Coding: 3D3F4FC207002102
Shop #: WSC 06314 000 00000
1 Fault Found
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 7
Reset counter: 45
Mileage: 43066 km
Time Indication: 0
Date: 2009.04.06
Time: 18:36:11
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 L HW: 8P0 035 192 L
Component: RNS-E HIGH EU H74 0650
Revision: 55S Serial number: AUZBZDA9942180
Coding: 0205717
Shop #: WSC 00046 412 40960
2 Faults Found
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 43066 km
Time Indication: 0
Date: 2009.04.06
Time: 18:37:05
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 43066 km
Time Indication: 0
Date: 2009.04.06
Time: 18:36:20
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0205717
2 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 43066 km
Time Indication: 0
Date: 2009.04.06
Time: 18:37:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 43066 km
Time Indication: 0
Date: 2009.04.06
Time: 18:36:20
Coding: 00062736
Shop #: WSC 06314
1 Fault Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 45
Mileage: 43066 km
Time Indication: 0
Date: 2009.04.06
Time: 18:36:00
Freeze Frame:
ON
Voltage: 14.10 V
ON
ON
OFF
OFF
OFF
1 Fault Found
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 7
Reset counter: 45
Mileage: 43066 km
Time Indication: 0
Date: 2009.04.06
Time: 18:36:11
Coding: 0205717
2 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 43066 km
Time Indication: 0
Date: 2009.04.06
Time: 18:37:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 43066 km
Time Indication: 0
Date: 2009.04.06
Time: 18:36:20
Coding: 0205717
2 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 43066 km
Time Indication: 0
Date: 2009.04.06
Time: 18:37:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 43066 km
Time Indication: 0
Date: 2009.04.06
Time: 18:36:20
