Erros no LOG com o VAG-COM
Tópico em 'Eletrónica e VAG-COM' iniciado por cuto, 21 Nov 2007.
  1. cuto
    cuto
    Desde:
    4 Nov 2007
    871
    Gostos Recebidos:
    4
    Agora acho que descobri um problema GRAVE: vejam isto,
    Tuesday,20,November,2007,23:16:50
    VAG-COM Version: Release 607.3-UD
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    Address 01: Engine
    Part No: 038 906 019 JL
    Component: 1,9l R4 EDC 0000SG 1519
    Coding: 00002
    Shop #: WSC 63351
    WAUZZZ8E02A275010 AUZ6Z0B0045375
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes
    Part No: 8E0 614 517
    Component: ABS/ESP front 1726
    Coding: 04255
    Shop #: WSC 06435
    Address 08: Auto HVAC
    Part No: 8E0 820 043 C
    Component: A4 Klimaautomat 1012
    Coding: 00000
    Shop #: WSC 63351
    4 Faults Found:
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    41-10 - Blocked or No Voltage - Intermittent
    01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
    30-10 - Open or Short to Plus - Intermittent
    01274 - Air Flow Flap Positioning Motor (V71)
    01794 - Control Module - Incorrect Chassis (VIN) Number
    35-00 - -
    Address 09: Cent. Elect.
    Part No: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00111
    Shop #: WSC 00000
    1 Fault Found:
    35-00 - -
    Address 15: Airbags
    Part No: 8E0 959 655
    Component: Airbag 8.4E 5001
    Coding: 0010602
    Shop #: WSC 63351
    Address 16: Steering wheel
    Part No: 8E0 953 549 F
    Component: Lenksáulenmodul 0308
    Coding: 00012
    Shop #: WSC 63351
    1 Fault Found:
    35-00 - -
    Address 17: Instruments
    Part No: 8E0 920 930 J
    Component: KOMBI+WEGFAHRS. RB4 D27
    Coding: 00000
    Shop #: WSC 00046
    Part No: 75010
    Component: AUZ6Z0B0045375
    1 Fault Found:
    01300 - Control Module for Navigation with CD-Rom (J401)
    49-10 - No Communications - Intermittent
    Address 37: Navigation
    Part No: 8E0 035 192 B
    Component: RNS 4.2 H06 BNO 0102
    Address 46: Central Conv.
    Part No: 8E0 959 433 AG
    Component: Komfortgerát T87 0316
    Coding: 06976
    Shop #: WSC 63351
    Part No: 8E1959801B
    Component: Tõrsteuer.FS BRM 0002
    Part No: 8E1959802B
    Component: Tõrsteuer.BF BRM 0002
    Address 55: Xenon Range
    Part No: 4Z7 907 357
    Component: dynamische LWR D07
    Coding: 00060
    Shop #: WSC 63351
    Address 56: Radio
    Component: Radio BNO 0001
    Coding: 00015
    Shop #: WSC 77496
    End --------------------------------------------------------------------------------------------------
    Erro no chassis????????? fdxxxxx.....
    Tb. não me deixou mexer no fecho automático das portas.
  2. artur
    artur Guest
    não tens ai nada de grave na caminete . o erro de vin , é da codificação dos modulos , ou seja , os vin dos modulos não estão codificados correctamente mas não afecta o seu funcionamento . tenho algures escrito isso como resolvi na minha , depois explico te isso . a unica coisa que esta ai de errado , sao os motores da distribuição do ar , que não é defeito mas sim feitio , ficam atras do porta luvas e requer algum trabalho .... mas ha ai no forum info sobre isso
    abraçoooo
  3. artur
    artur Guest
    depois bota ai as novidades daquilo que te disse no msn para fazeres ;)
    ps - não passaram a promessa do home ....... 4 francesinhas aqui po je :D :D :D
  4. rmatos
    rmatos
    Desde:
    31 Jan 2006
    13 294
    Gostos Recebidos:
    97
    Ora vai lá procurar isso para explicares aqui ao teu amigo ;)
  5. artur
    artur Guest
    a minha camionete tambem tinha isso no modulo do ac . deve ter sido trocado ou qq coisa do genero .
    no modulo do ac , vais a adaptation , depois channel 80 e qualquer , poes um numero que nao tenho aqui de cabeça ( depois digo te ) o vag lê o vin do componente em questão e voilá , desaparece o erro ....... horas de search amigo ......
  6. ELFuracon
    ELFuracon
    Desde:
    9 Dez 2006
    2 017
    Gostos Recebidos:
    557
    Se ajudar....
    Audi A4 (8E) Heating/Air Conditioning
    Address 08
    Coding
    00?xx: Chassis
    0 = Sedan/Avant
    1 = Cabrio
    00x?x: Heated Windshield
    0 = Heated Windshield not installed
    1 = Heated Windshield installed
    00xx?: Sunroof
    0 = No Sunroof OR Normal Sunroof
    1 = Sunroof with Solar Cells
    Adaptation
    Channel 081: Vehicle Data Learning
    To start the process for vehicle data (VIN) learning, enter/save 26467 as new value.
  7. rmatos
    rmatos
    Desde:
    31 Jan 2006
    13 294
    Gostos Recebidos:
    97
    Ajuda sim senhor El furacon
    Muito obrigado ;)
  8. ELFuracon
    ELFuracon
    Desde:
    9 Dez 2006
    2 017
    Gostos Recebidos:
    557
    De nada...estamos cá é para isso!
  9. cuto
    cuto
    Desde:
    4 Nov 2007
    871
    Gostos Recebidos:
    4
    Tão prometidas! 4 francesas pro artur (sem pernas....). Funcionou o tranco automático das portas através do coding. Qto ao modulo que refere o El furacan, o vag-com dá mesmo essa indicação, bem que pus lá o número, mas falha no teste e põe a zero.
    P.S. artur quem me fez a repro diz que é normal que não dê para repôr esse valor ;)
  10. ELFuracon
    ELFuracon
    Desde:
    9 Dez 2006
    2 017
    Gostos Recebidos:
    557
    Bem...Vamos por partes.
    Relativamente a este erro:
    Coding: 00111
    Shop #: WSC 00000
    1 Fault Found:
    35-00 - -
    Já experimentaste?:
    em adaptation
    Channel 081: Component Protection
    To start the process of Vehicle Identification Number (VIN) learning, enter/save 46992 as new value
    Relativamente a:
    Coding: 00012
    Shop #: WSC 63351
    1 Fault Found:
    35-00 - -
    Adaptation
    To start the process for vehicle data (VIN) learning, enter/save 00111 as new value.
    Se não, 1ºexperimenta e depois falamos sobre as codificações.
  11. cuto
    cuto
    Desde:
    4 Nov 2007
    871
    Gostos Recebidos:
    4
    Oléeeee,
    Experimentei apenas isto:
    Adaptation
    Mas amanhã testo com os que postaste e já mando fio-de-béque!
Partilhar esta página
