erros na minha A4
Boa tarde, tenho uma A4 Avant B6 de 2002 e há dias ao fechá-la com o comando reparei que a luzinha da porta ( julgo que do imobilizador) não acendeu, verifiquei se a porta do condutor estava fechada e não estava, ou seja fechou todas menos a do condutor. Depois de meter o vagcom saiu-me esta lista de erros, alguém me pode ajudar?
Sunday,23,December,2012,12:43:51:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E12A247930 Mileage: 196030km/121807miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 FP
Component: 1,9l R4 EDC 0000SG 1538
Coding: 00002
Shop #: WSC 63351
VCID: 6AD0C0F67A25FF4C
WAUZZZ8E12A247930 AUZ6Z0B0042418
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
VCID: E5CA33CA133B5034
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043
Component: A4 Klimaautomat 1012
Coding: 00000
Shop #: WSC 63351
VCID: DEB81C26366D03EC
4 Faults Found
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
00474 - Control Module for Immobilizer
49-10 - No Communications - Intermittent
27-10 - Implausible Signal - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 C
Component: int. Lastmodul RDW 0203
Coding: 00001
Shop #: WSC 63351
VCID: 326018969275778C
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 5001
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: F4EC5E8EA8E1B9BC
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00002
Shop #: WSC 63351
VCID: 366824867E1D6BAC
1 Fault Found
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 00000
Shop #: WSC 00000
VCID: 2854FAFEA4A90D5C
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AG
Component: Komfortgerát T87 0315
Coding: 06976
Shop #: WSC 63351
VCID: 76E8E4863E9D2BAC
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
7 Faults Found
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
61-10 - Won't De-Safe - Intermittent
01562 - Right Rear Door
61-00 - Won't De-Safe
01331 - Door Control Module; Driver Side (J386)
80-00 - Single-Wire Operation
01559 - Drivers Door
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
37-00 - Faulty
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186
Component: concert II GRO 0007
Coding: 00001
Shop #: WSC 63351
VCID: E4CC2ECE1801293C
1 Fault Found
01317 - Control Module in Instrument Cluster (J285)
antes de mais limpa esses erros todos, pois é provavel que muitos sejam antigos...
andas um dia e volta a ligar o vag, e diz quais os erros que reapareceram...
quanto ao teu problema, pode ser várias coisas, mas uma das coisas que acontece em várias/vários b6 é a cablagem, ou seja os fios que passam para a porta, entre as dobradiças da porta, com o abrir e fechar acabam por partir e deixam de fazer ligação...
Coding: 00000
Shop #: WSC 63351
4 Faults Found
TENS DE LUBRIFICAR AS FLAPS QUE ESTÂO PERRAS OU PRESAS
_______________________________________________________________________________
Coding: 06976
Shop #: WSC 63351
Part No: 8E1959801B
Part No: 8E1959802B
7 Faults Found
37-00 - Faulty
DEVERÀS TER MAU CONTACTO NAS FICHAS OU FIO TRAÇADO
Limpa os erros todos e dá uma voltinha e faz novo scan para confirmar.
Já agora, verifica o estado da bateria.
Boas
Obrigado pelas dicas, vou verificar e depois digo alguma coisa.
A bateria anterior falhou e eu comprei uma nova à 1 semana.
Há duas semanas verifiquei com o cabo vagcom e os erros os mesmos menos o Steering whel1 e o rádio.
Mais uma vez obrigado pela vossa ajuda
