Bem pessoal estive fora durante muito tempo, devido ao trabalho....
Mas estou de volta...
Tenho aki um problema em maos, e k nao sei cm resolver, aki estao os erros
Estes deram a coisa de uma semana, e apaguei!
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 038 906 019 FT
Component: 1,9l R4 EDC 0200SG 1527
Coding: 00002
Shop #: WSC 06435
WAUZZZ8L83A011825 AUZ7Z0B2114505
2 Faults Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019970
Shop #: WSC 06435
1 Fault Found:
65534 - Unknown Error Code
015 - Cannot Be Tested at this Time
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 J
Component: A3 KLIMAAUT
Note: Excessive Comm Errors
Address 15 -------------------------------------------------------
Controller: 8L0 959 655 L
Component: Airbag Front+Seite 7008
Coding: 00104
Shop #: WSC 06435
No fault code found.
Address 17 -------------------------------------------------------
Controller: 8L0 920 932 E
Component: KOMBI+WEGFAHRS. VDO D10
Coding: 04040
Shop #: WSC 00050
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14945
Shop #: WSC 06435
Address 56 -------------------------------------------------------
Controller: 8L0 035 186 G
Component: concert II GRO 0008
Coding: 00000
Shop #: WSC 06435
End -------------------------------------------------------
De Seguida hoje deram estes...
Coding: 00002
Shop #: WSC 06435
Coding: 0019970
Shop #: WSC 06435
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Skipping Address 15-Airbags
Coding: 04040
Shop #: WSC 00050
1 Fault Found:
49-10 - No Communications - Intermittent
Coding: 14945
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 06435
Coding: 00002
Shop #: WSC 06435
2 Faults Found:
Readiness: N/A
Coding: 0019970
Shop #: WSC 06435
1 Fault Found:
Coding: 00104
Shop #: WSC 06435
Coding: 04040
Shop #: WSC 00050
Coding: 14945
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 06435
Coding: 00002
Shop #: WSC 06435
Coding: 0019970
Shop #: WSC 06435
1 Fault Found:
Coding: 04040
Shop #: WSC 00050
1 Fault Found:
Coding: 14945
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 06435
