sumodos300
Utilizador Banido
Boas.
um migo meu anda a ver carros pa patroa e viu um Beetle
mt fixe,fui la com ele e meti o vag com e deu isto.
Address 01: Engine
Part No: 038 906 018 AP
Component: 1,9l R4 EDC G000SG 2124
Coding: 00002
Shop #: WSC 00066
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Part No: 1J0 907 379 S
Component: ESP 20 CAN V010
Coding: 00241
Shop #: WSC 00066
1 Fault Found:
00538 - Reference Voltage
57-10 - Electric Circuit Failure - Intermittent
Address 15: Airbags
Part No: 1J0 909 609
Component: D AIRBAG VW3 SG 0002
Coding: 00068
Shop #: WSC 00066
No fault code found.
Address 17: Instruments
Part No: 1C0 919 861 A
Component: KOMBI+WEGFAHRS. M73 V23
Coding: 00142
Shop #: WSC 00000
Part No: Ident
Component: Nr. Wegfahrs.:VWZ5Z0X2312372
Ident.-Nr. Wegfahrs.:VWZ5Z0X2312372
Address 46: Central Conv.
Part No: 1J0 959 799 AH
Component: 5W Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 00066
Part No: 1J2959802C
Component: 5W Tõrsteuerger. FS0001r
Part No: 1J2959801D
Component: 5W Tõrsteuerger. BF0001r
5 Faults Found:
01483 - Control Circuit for Rear Lid Remote Unlocking
25-10 - Unknown Switch Condition - Intermittent
01331 - Door Control Module; Driver Side (J386)
53-10 - Supply Voltage Too Low - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
Address 56: Radio
Part No: 1C0 035 186
Component: Radio 0001
Coding: 08401
Shop #: WSC 00066
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End --------------------------------------------------------------------------------------------------
Tem erros dos espelhos n akecerem mas ele vi por dentro e n tem no manipulo dos espelhos a opcao de akecer...e tem o erros pa mala e realmente nao abre com o camando...
alguem ve algo de relevante?
Address 01: Engine
Coding: 00002
Shop #: WSC 00066
1 Fault Found:
Readiness: N/A
Coding: 00241
Shop #: WSC 00066
1 Fault Found:
Address 15: Airbags
Coding: 00068
Shop #: WSC 00066
Coding: 00142
Shop #: WSC 00000
Part No: Ident
Coding: 00257
Shop #: WSC 00066
Part No: 1J2959802C
Part No: 1J2959801D
5 Faults Found:
35-00 - -
35-00 - -
Address 56: Radio
Coding: 08401
Shop #: WSC 00066
1 Fault Found:
