Erros do meu bolinhas... :S
Boas o assunto que me traz foi a quantidade de erros que o meu bolinha e que aos quais fiz clean e nada resolveu. voltaram a aparecer os mesmos.
Se alguem poder ajudar ficaria grato. :)
VCDS Version: Release 10.6.2
Data version: 20101123
Tuesday,31,May,2011,21:47:44:36838
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8H94K018418 Mileage: 159040km/98822miles
Address 01: Engine Labels: 059-907-401-AKE.lbl
Part No: 8E0 907 401 T
Component: 2.5l V6 TDI 0000SG 0006
Coding: 07002
Shop #: WSC 00672
VCID: 36683A5C383B
Part No: 00006059
Component: 130 106KC318_1.V14982735392
WAUZZZ8H94K018418 AUZ6Z0C0426236
1 Fault Found:
00550 - Start of Injection Regulation
08-00 - Control Limit Surpassed
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04455
Shop #: WSC 00672
VCID: E5CA2D10551D
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AB
Component: A4 Klimaautomat 1323
Coding: 00100
Shop #: WSC 00672
VCID: 61C2B900C135
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 C
Component: int. Lastmodul RDW 0606
Coding: 00101
Shop #: WSC 00672
VCID: 3260064CD453
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 B
Component: Airbag 8.4EC 2015
Coding: 0011104
Shop #: WSC 00672 785 00200
VCID: 397231600925
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 03001
Shop #: WSC 00672
VCID: 3E78227C100B
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 900 D
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 00001
Shop #: WSC 65535
VCID: 2854E424E28F
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411
Coding: 00001
Shop #: WSC 36391
VCID: EFE64F3887E1
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 F
Component: Komfortgerát T3B 3220
Coding: 06698
Shop #: WSC 00672
VCID: 377637583F31
Part No: 8H1959801A
Component: Tõrsteuer.FS BRM 0003
Part No: 8H1959802A
Component: Tõrsteuer.BF BRM 0001
Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0002
Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0002
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 M
Component: concert II GRO 0001
Coding: 13005
Shop #: WSC 00672
VCID: 31620940D155
2 Faults Found:
00856 - Radio Antenna
36-00 - Open Circuit
00858 - Connection; Radio ZF Output to Antenna Amplifier
29-00 - Short to Ground
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00105
Shop #: WSC 00672
VCID: 438E53887BE9
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 A HW: 8P0 862 335 A
Component: FSE_255x BT H17 0030
Revision: 00000001 Serial number: 00000000037788
Coding: 0000601
VCID: 346C00542E47
tens ai um erro de air bag, por acaso ñ tens a dita luz acessa?
tb podes começar a vereficar a ficha e o cabo k liga ao senssor de temperatura, se tiver tudo ok substitui o senssor, pois tb esta a dar erro..
podes ter tb ai um problema de injecçao ou na bomba..
faz um log aos injectores
tenho amigo, o raio da luz nao quer apagar e ja verifiquei as fichas por baixo do banco e esta tudo em ordem.
O sensor penso que seja o G62 ne? Ja o tenho encomendado para trocar..
Agr a situação da bomba ou injectores ek nao entendo o carro anda igual, nao noto diferença nenhuma.. :S
Como faço um log aos injectores?
o erro de air bag é o do lado do condutor, ve se ñ tens nenhum cabo danificado ou fixa, e faz uma limpeza aos terminais..
quanto ao log dos injectores faz por aki um :search: k vais encontrar
faz o seguinte apagas os erros e depois das uma volta e tornas a fazer o scan, para ver se não são erros ''esporádicos''.
Amigo, embora saiba que o forum dispoes de um Search... nao consigo utilizalo, pois a pesquisa traz muita palha a mistura. Provavelmente irias pesquisar isso durante horas e nao iria encontrar nada de concreto. Se poderes me ajudar ou indicar o topico caso saibas onde ele esta ficaria grato. caso contrario tenho mesm que ir pesquisar.
vou dar uma vista de olhos
é importante salientar que uma vez acendeu a luz do motor e o ponteiro da tem caiu para o 0º tera alguma coisa a ver com issO?
quanto ao log dos injectores ñ encontrei nada de especial, mas fala com o user VITOR FARIA k ele é mestre no VAG-COM
quanto a luz do motor acender sim pode ter a ver com esse erro
vou chatear entao o amigo victor.. vamos ver o que ele diz. :D
Mas o carro pucha igual... nao noto dif nenhuma...
