Finalmente fiz o Diagnosticos na minha b6 e deu os seguintes erros:
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Controller: 038 906 019 FP
Component: 1,9l R4 EDC 0000SG 1467
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E32A204044 AUZ6Z0A0295393
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 B
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
00819 - High Pressure Sensor (G65)
30-00 - Open or Short to B+
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 J
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 00000
Shop #: WSC 26200
3 Faults Found:
00779 - Outside Air Temp Sensor (G17)
01304 - Radio
49-00 - No Communications
01300 - Control Module for Navigation with CD-Rom (J401)
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 06976
Shop #: WSC 63351
2 Faults Found:
01561 - Left Rear Door
61-00 - Won't De-Safe
01562 - Right Rear Door
End -------------------------------------------------------
Alguem me pode explicar o que querem dizer e o que esta mal?
Coding: 00002
Shop #: WSC 63351
Coding: 04255
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
Coding: 00001
Shop #: WSC 63351
Coding: 00012
Shop #: WSC 63351
Coding: 00000
Shop #: WSC 26200
3 Faults Found:
01304 - Radio
Coding: 06976
Shop #: WSC 63351
2 Faults Found:
