Erros com O VAG-COM
Hoje é a minha vez ;) ;)
1ª Leitura
Sunday,08,February,2009,18:49:17
VAG-COM Version: Release 607.3-UD
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN Number: WXXXXXXXXXXXXXXXX
Address 01: Engine
Part No SW: 03G 906 016 FP HW: 028 101 212 8
Component: R4 2,0L EDC 000SG 9383
Coding: 0000072
Shop #: WSC 21028
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H05 0120
Coding: 0004401
Shop #: WSC 06325
Address 08: Auto HVAC
Part No: 8E0 820 043 AM
Component: A4 Klimaautomat 2831
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect.
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0504
Coding: 10001
Shop #: WSC 06325
1 Fault Found:
02738 - Bulb for Tail/Brake Light; Left
30-00 - Open or Short to Plus
Address 15: Airbags
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Coding: 0033622
Shop #: WSC 06325
Address 16: Steering wheel
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 00012
Shop #: WSC 06325
Address 17: Instruments
Part No SW: 8E0 920 931 P HW: 8E0 920 931 P
Component: KOMBI+WFS 4 H12 0110
Coding: 0006041
Shop #: WSC 00000
Address 37: Navigation
Part No SW: 8E0 035 192 D HW: 8E0 035 192 D
Component: RNS-E HIGH EU H70 0360
Coding: 0301711
Shop #: WSC 06348
1 Fault Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 96
Time Indication: 0
Date: 2009.02.07
Time: 11:05:05
Freeze Frame:
Bin. Bits: 0000
Mileage: 655350 km
Count: 802
Clock: 14:31
Address 46: Central Conv.
Part No: 8E0 959 433 BP
Component: Komfortgerát T85 3332
Coding: 07024
Shop #: WSC 06325
Part No: 8E1959801H
Component: Tõrsteuer.FS BRM 0406
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Address 56: Radio
Coding: 0301711
Shop #: WSC 06348
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 96
Time Indication: 0
Date: 2009.02.07
Time: 11:05:05
Freeze Frame:
Bin. Bits: 0000
Mileage: 655350 km
Count: 802
Clock: 14:31
Address 77: Telephone
Part No SW: 8P0 862 335 C HW: 8P0 862 335 C
Component: FSE_255x BT H18 0160
Coding: 0010711
Shop #: WSC 06325
End --------------------------------------------------------------------------------------------------
Após o Claer dos DTC todos não apresentou mais erros nenhuns
ja sabes se daqui a uns tempos fazes outro autoscan e todos os erros que aparecerem e pq tens se nao aparecer nao tens erros, pq esses erros sao de problemas antigamente e que nao foram limpos aquando a sua resolucao, abracos :green:
Há dias de sorte :green:
Andam por aí argolas que mesmo apagando os erros eles ficam lá na mesma á espera de t€mpo :D
Aproveitando o mesmo topico e para nao abrir outro aqui vai o meu 1º Log ...
Sunday,08,February,2009,13:35:25:21461
VCDS Version: Release 805.1
Data version: 20080823
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: ------------------------- Mileage: 167380km/104005miles
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 FT
Component: 1,9l R4 EDC 0000SG 1527
Coding: 00002
Shop #: WSC 06435
WAUZZZ8L42A067324 AUZ7Z0B2040702
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019970
Shop #: WSC 06435 000 00000
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 J
Component: A3 KLIMAAUTOMAT 0101
Coding: 00040
Shop #: WSC 06435
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 4008
Coding: 00104
Shop #: WSC 06435
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 932 D
Component: KOMBI+WEGFAHRS. VDO D09
Coding: 04040
Shop #: WSC 19411
Part No: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14945
Shop #: WSC 06435
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8L0 035 186 G
Component: concert II GRO 0008
Coding: 00201
Shop #: WSC 06435
1 Fault Found
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
Alguem com melhores conhecimentos que me "traduza" isto ?
Obrigado!!!
Limpa o erro.
Isso foi uma altura em que desligaram o radio e não tinha a ficha diversity ligada.
Se o erro não desaparecer é porque ainda está desligada!
ELFuracon disse:
Limpa o erro.
Boas, já fiz isso mas o erro mantém-se... devo ter de sacar o radio então para ver isso certo? Se assim for tenho de arranjar os "saca radio" da Audi pois não os tenho.
Obrigado pela resposta! :)
bantunes disse:
se precisares das chaves comunica.. ;)
