Fiz um scan e deu-me o seguinte log:
Chassis Type: 4D - Audi A8 D2
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,65,76
Controller: 4D0 907 557 G
Component: 4.2L V8/4V MOTR HS D01
Coding: 04213
Shop #: WSC 00000
3 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
17916 - Idle Control Sys: Upper Regulation Limit Reached
P1508 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 M
Component: ABS/EDS 5.3 QUATTRO D11
Coding: 0273004134
Shop #: BB 24302
No fault code found.
Address 08 -------------------------------------------------------
Controller: 4D0 820 043 E
Component: D2-KLIMAVOLLAUTOMAT_D03
Coding: 00180
Shop #: WSC 02314
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4D0 919 033 S
Component: D2-KOMBIINSTRUMENT D40
Coding: 00183
Shop #: WSC 02314
Address 35 -------------------------------------------------------
Controller: 8LO 862 257
Component: ZV-Pumpe, DWA, Funk
Coding: 10184
Shop #: WSC 65535
2 Faults Found:
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
End -------------------------------------------------------
Alguem me consegue explicar a que se devem os erros, principalmente os 3 primeiros, do motor
obrigado
Coding: 04213
Shop #: WSC 00000
3 Faults Found:
Readiness: N/A
Coding: 0273004134
Shop #: BB 24302
Coding: 00180
Shop #: WSC 02314
Coding: 00183
Shop #: WSC 02314
Coding: 10184
Shop #: WSC 65535
2 Faults Found:
35-00 - -
35-00 - -
obrigado
