Erros Audi A3 8P
Boas Malta!
Venho em vosso auxílio!
Tenho alguns erros após efetuar uma pesquisa no meu VCDS! Sou novo nestas andanças, pois comprei devido ao facto de querer codificar o RNS-E que comprei (ainda não fiz) e alterar a lingua que estava em alemão para espanhol ou inglês (que já fiz)
Estado Geral:
Code:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
3D-Special Function -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
5D-Operations -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Erros em detalhe:
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 N HW: 8P0 820 043 N
Component: KlimavollautomatH18 0260
Revision: 084915 Serial number: 8P0820043N
Shop #: WSC 06314 000 00000
VCID: 377D9EDB464D8D3573-8062
1 Fault Found:
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 364805 km
Time Indication: 0
Date: 2023.03.01
Time: 16:10:32
Freeze Frame:
ON
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H44 1102
Revision: 00H44000 Serial number: 00000002345201
Coding: 01884F019214100000160000160000000008FE175C0100
Shop #: WSC 06314 000 08192
VCID: 408FF5071383CA8DC2-8014
Subsystem 1 - Part No: 2K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 270607 021 0501
Coding: 00002022
Shop #: WSC 06314
3 Faults Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 5
Reset counter: 254
Mileage: 364561 km
Time Indication: 0
Date: 2023.02.25
Time: 19:15:00
Freeze Frame:
OFF
Voltage: 13.30 V
OFF
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 3
Reset counter: 36
Mileage: 364519 km
Time Indication: 0
Date: 2023.02.23
Time: 18:21:00
Freeze Frame:
ON
Voltage: 14.20 V
ON
ON
OFF
OFF
OFF
00380 - Special Vehicle Control Module (J608)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 254
Mileage: 313494 km
Time Indication: 0
Date: 2019.09.30
Time: 15:32:00
Freeze Frame:
ON
Voltage: 12.50 V
ON
ON
OFF
OFF
OFF
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H34 0070
Coding: 0004012
VCID: 4189F0031889C385CD-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 G HW: 1K0 907 951
Component: J533__Gateway H10 0140
Revision: H10 Serial number: 3000105C088E7B
Coding: 3D3F0FEB17002102
VCID: 2B55B2AB8A0539D507-807E
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 254
Mileage: 313494 km
Time Indication: 0
Date: 2019.09.30
Time: 15:29:40
02749 - Control Module / Control Head for Telephone (J738)
Freeze Frame:
Fault Priority: 2
Reset counter: 254
Mileage: 313494 km
Time Indication: 0
Date: 2019.09.30
Time: 15:29:41
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Reset counter: 254
Mileage: 313494 km
Time Indication: 0
Date: 2019.09.30
Time: 15:29:44
02649 - Digital Radio Tuner
Freeze Frame:
Fault Priority: 2
Reset counter: 254
Mileage: 313494 km
Time Indication: 0
Date: 2019.09.30
Time: 15:29:44
01304 - Radio
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 7
Reset counter: 37
Mileage: 364949 km
Time Indication: 0
Date: 2023.03.11
Time: 17:23:51
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000176
1 Fault Found:
01706 - Switch for Mirror-Adjust (E43)
008 - Implausible Signal
Address 5D: Operations
Cannot be reached
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 F HW: 8P0 862 335 F
Component: FSE_255x BT H21 0190
Revision: 00000001 Serial number: 00000000363780
Coding: 0001211
VCID: 397998E370599B4585-806C
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 36
Mileage: 364949 km
Time Indication: 0
Date: 2023.03.11
Time: 17:24:00
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
Shop #: WSC 00000 000 00000
VCID: 2D51BCB3B41137E519-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
Gostava de perceber que erros são estes e como os posso solucionar.
Desde já obrigado a todos!
Okapa, então irei fazer isso, ainda tenho de fazer o serviço e após isso apago os erros! Desde já obrigado pela resposta @jimy !
Meus caros! Mais uma vez hoje liguei o A3 ao VCDS e limpei os erros! Porém, não os limpou todos! Vejam a foto abaixo:
O Navigation é normal pois não o tenho instalado, mas o restante acho esquisito não limpar...
Alguém sabe o que poderei fazer?
Que radio tens?
Mais informação, rigor e pormenor (para não andar aqui a arrancar informação)
Alguma coisa não funciona?
Estás a alterar instalar algo?
Anomalias?
Relatório detalhado p.f.
Se não consegues instalar e codificar o rns-e, podes pedir ajuda online ao user Jimy. É questão de falares sobre o assunto com ele e acertar tudo.
Olá @madlima29! Sim, vou configurar o RNS-E, pelo que vi num tutorial não me parece ser difícil, mas caso precise de ajuda eu irei falar com o @jimy!
Eu agora não tenho o pc windows comigo mas eu fiz um save desses erros e mais logo já posto aqui! Se bem que o o Aux Heat e o AutoHVAC penso que nada têm haver com o novo rádio. Os Erros que dão nesses dois são estes:
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 364805 km
Time Indication: 0
Date: 2023.03.01
Time: 16:10:32
Freeze Frame:
ON
E este
1 Fault Found:
014 - Defective
Desde já obrigado por tudo!
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 364805 km
Time Indication: 0
Date: 2023.03.01
Time: 16:10:32
Freeze Frame:
ON
E este
1 Fault Found:
014 - Defective
Isso avaria no radiador eléctrico.
Para lhe aceder, tens de desmontar a forra sob o volante, e toda a consola central. Depois o elemento está junto ao radiador da chaufagem.
Ou o substituis, ou tentas reparar. Geralmente tem umas resistências que ficam com as soldas estaladas. E depois de resolvido fica bom. Não quer isto dizer que não possa ser mesmo o elemento queimado, mas geralmente não.
Portanto muita lavoura e trabalho, mas faz separa quem tiver habituado.
Esse elemento aquece electricamente o habitáculo, desde que a temperatura ambiente esteja abaixo de 10°C, anticongelante abaixo de 65/70°C e activado o climatronic para quente.
Se pesquisares na net, acho que deve haver DIY disso, ou videos, quanto mais não seja de VWs.
@madlima29, desde já obrigado! Já vi uns vídeos e ao montar o RNS-E talvez me aventure a fazer isso no fim‑de‑semana! Vou mandar vir resistências novas para mudar isso! Desde já obrigado por tudo! :)
Já tenho aqui o ficheiro com os erros completos, após limpar e dar um girinho com o carro!
Coding: 00002022
Shop #: WSC 06314
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 5
Mileage: 365082 km
Time Indication: 0
Date: 2023.03.14
Time: 16:38:00
Freeze Frame:
ON
Voltage: 12.50 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 35
Reset counter: 5
Mileage: 365082 km
Time Indication: 0
Date: 2023.03.14
Time: 16:38:00
Freeze Frame:
ON
Voltage: 12.50 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio
Cannot be reached
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 5
Mileage: 365082 km
Time Indication: 0
Date: 2023.03.14
Time: 16:38:19
Freeze Frame:
Fault Priority: 2
Fault Frequency: 25
Reset counter: 5
Mileage: 365082 km
Time Indication: 0
Date: 2023.03.14
Time: 16:38:20
Freeze Frame:
Fault Priority: 2
Fault Frequency: 25
Reset counter: 5
Mileage: 365082 km
Time Indication: 0
Date: 2023.03.14
Time: 16:38:23
Freeze Frame:
Fault Priority: 2
Fault Frequency: 25
Reset counter: 5
Mileage: 365082 km
Time Indication: 0
Date: 2023.03.14
Time: 16:38:23
o botão para reduzir a intensidade da iluminação interior funciona?
Mexeste no coding do 19-Can Gateway? está se a queixar que não tem comunicação com diversos modulos, os 3 ultimos deve de ser referente ao RNS-E e telefone (bluetooth) , o primeiro é o modulo de função especifica do carro (Se o carro tinha isso de origem, esse carro pode ter servido em serviços de emergência ou assim, não tens nenhum botão que diz "FUNK" na consola?
Olá @BlueA4! Desde já obrigado pela mensagem!
Opá, funciona mal, aliás, eu até queria comprar esse switch mas n está fácil para arranjar!
Não, eu pelo menos não mexi no código de CAN. Na consola não vejo nenhum botão que diga FUNK.
Desde já obrigado!
00380 - Special Vehicle Control Module (J608).
Pergunto eu se as escovas limpa vidros funcionam corretamente, e/ou se recodificaste? Tens xenon aftermarket?
O switch das luzes (dimmer) limpas com spray de contactos na ficha o no botão dentro. Deve resolver. Se não, trocas. Compras um na sucata. Até online há até aos 30€.
O resto tem a ver com o RNS e por codificar
Grande @madlima29 que tanto me ajudas! :)
Sim, tenho! Há alguma maneira de o codificar?
Eu pelo menos nunca fiz nada!
Olha, por acaso eu já andei à procura do conjunto dos 3 botões (Farois, reg. altura e iluminação interior), mas não encontro, até queria ver se arranjava uma versão com cromados.
Já agora quanto custa os switch de vidros do lado do condutor numa sucata (+/-)?
Desculpem o meu desconhecimento nestas áreas, mas tudo que sei ou aprendi aqui ou no youtube! :)
Xenon imediatamente fora.
Ou metes original, ou só um kit de alta qualidade, que sinceramente não sei se aí da existe.
Xenon que não original queima o motor de limpa vidros e a BCM.
Fora com isso.
O botão ainda agora vi na net, e encontrei a 30€ (cromado tens as capas ou acessórios parciais no aliexpress barato assim como os botões dos vidros também a volta de 25/30€
Depois de remover o xenon, apaga os erros e volta a fazer um scan com o vcds.
