Seat Error Vag-Com
Necessito de ajuda com 2 error que aparecem no Auto-Scan do Vag-Com:
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 HW: 6R0 937 087
Component: PQ25 BCM H06 0013
Revision: BF006001 Serial number: 9425A167080503
Coding: 7C882BA88873250093300600764B1EC800C0400F608C00002000
Shop #: WSC 15638 784 18382
VCID: FAF1034C75C4C6E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 13060 54 0402
Coding: 03012D
Subsystem 2 - Part No SW: 6R0 959 801 A HW: 6R0 959 801 A Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 001 0220
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 802 C HW: 6R0 959 802 C
Component: J387__TSG_BT 001 0224
Coding: 020000
Subsystem 4 - Part No: 1K8 951 171 A
Component: DWA-Sensor 001 0103
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 D
Component: LIN BACKUP HO H08 9001
Coding: 000000
Subsystem 6 - Part No: 1K8 951 171 A
Coding: 000000
Subsystem 7 - Part No SW: 6R0 959 811 HW: 6R0 959 811
Component: J388__TSG_HL 001 0227
Coding: 000000
Subsystem 8 - Part No SW: 6R0 959 812 HW: 6R0 959 812
Component: J389__TSG_HR 001 0228
Coding: 000000
1 Fault Found:
00063 - Back-Up Light Switch (F4)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 181
Mileage: 67989 km
Time Indication: 0
Date: 2111.14.02
Time: 17:42:21
E o outro é:
Address 03: ABS Brakes (J104) Labels: 6J0-907-37x-ESP.clb
Part No SW: 6R0 907 379 H HW: 6R0 907 379 H
Component: ESP8.2i front H04 0005
Revision: --------
Coding: 110228DB016F00B8882A14EB80DA00401300
Shop #: WSC 04941 000 00000
VCID: 438F3EA8C68EC76
1 Fault Found:
01155 - Clutch
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 0
Fault Frequency: 4
Reset counter: 131
Mileage: 67753 km
Time Indication: 0
Date: 2110.14.26
Time: 08:03:44
Freeze Frame:
Hex Value: 0xC000
Hex Value: 0x8000
Hex Value: 0x3249
Hex Value: 0x25B5
Hex Value: 0x0A7F
Hex Value: 0x7F7F
Hex Value: 0x7EF9
Hex Value: 0x0000
Não sei se por coincidência ou não e relacionado com este último erro, o Hill Hold Assist não esta a funcionar.
Alguém me pode dar uma ajuda?
Obrigado e cumprimentos,
Olá joaosimiao,
O 1º erro está numa lâmpada ou no suporte da lâmpada que pode estar com mau contato, ou então tens fundida a luz de marcha a trás. o 2º erro já me aconteceu uma vez após ter feito uma condução agressiva e deve ter sido isso que causou o sensor dar-me esse erro. Após inspeção visual e limpeza junto das pastilhas e claro apagar o erro... nunca mais apareceu. Mas no teu caso tenta perceber o que se passa com o Hill Hold Assist porque no teu caso ao deixar de funcionar a causa do erro deve ser mesmo essa e não é coincidência. Vamos esperar por alguém que conheça o sistema Hill Hold Assist para opiniar.
Bons Km.
Coding: 03012D
Coding: 020000
Coding: 020000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 000000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 181
Mileage: 67989 km
Time Indication: 0
Date: 2111.14.02
Time: 17:42:21
E o outro é:
Revision: --------
1 Fault Found:
01155 - Clutch
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 131
Mileage: 67753 km
Time Indication: 0
Date: 2110.14.26
Time: 08:03:44
Freeze Frame:
Hex Value: 0xC000
Hex Value: 0x8000
Hex Value: 0x3249
Hex Value: 0x25B5
Hex Value: 0x0A7F
Hex Value: 0x7F7F
Hex Value: 0x7EF9
Hex Value: 0x0000
Olá paajf,
Obrigado pela tua resposta, mas preciso de mais uma ajuda, se souberes claro, onde se encontra o backup light switch? Quanto ao Hill Hold Assist, vou tentar dar uma olhada nas pastilhas...
Obrigado e Bom Natal
olá,
Senão me engano é uma relé que no meu Ibiza está por debaixo do volante (na zona dos pedais em direção ao volante). Essa relé é responsável pelo contato para que os as luzes dos stops funcionem em condições. Mas alguém por aqui também se deve pronunciar.
Boas entradas.
Olá paajf,
Boa tarde. Peço desculpa desde já pelo desenterro mas como já existe este tópico não acho necessario abrir um novo :roll:
Fiz hoje um Auto Scan ao meu Ibiza 6J e tive também o erro:
Part No SW: 6R0 937 087 H HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0230
Revision: BF046001 Serial number: 0147 337090544
Coding: 3C8829E888612500932000007E0B1EC80080400F608C0000200000000000
Shop #: WSC 48173 784 175189
VCID: 42813BAC6414
Component: RLS 261109 05 54 0402
Coding: 03302D
Part No SW: 6R0 959 801 N HW: 6R0 959 801 N
Component: J386__TSG_FT 003 3130
Coding: 020000
Part No SW: 6R0 959 802 Q HW: 6R0 959 802 Q
Component: J387__TSG_BT 003 3130
Coding: 020000
Component: DWA-Sensor 00 001 0103
Coding: 000000
Part No: 1K8 951 605
Component: LIN BACKUP HO H10 9003
Coding: 000000
Coding: 000000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 46875 km
Time Indication: 0
Date: 2105.14.10
Time: 14:14:55
Conseguiste resolver o teu erro? Alguém que me possa ajudar? Obrigado ;)
Apagas que isso é um erro intermitente.
Das uma volta e engatas a marcha atras e fazes novo scan.
Já nem deve aparecer nada.
Boas. Quando fiz esse scan, eliminei todos os erros e voltei e fazer scan e apareceu novamente... O meu Ibiza 6J SportCoupé só tem uma lampada de marca-atras, enquanto que o de 5 portas tem duas... Terá alguma coisa a ver? Obrigado!
Não.
E se isso nao passar, podes trocar a valvula de marcha atras que está apertada na caixa.
Mas tambem, enquanto funcionar tudo normalmente, deixa andar que nem é grave.
