Erro Vag-com
Boas pessoal
Venho por este meio pedir-vos ajuda.
Liguei o vag-com ao meu carro e hoje apareceu-me este erro: (05-Acc/Start Auth. -- Status: Malfunction 0010)
Será que me podem esclarecer a que se refere este erro.
abraços
Boas pessoal
abraços
parece que o erro esta incompleto, era só isso que estava escrito?
Não, esta foi a lista que saiu:
Chassis Type: 8T (8T0)
Scan: 01 03 05 08 09 0E 10 15 16 17 19 42 46 52 53 55 56 5F
VIN: WAUZZZ8T7AA004216 Mileage: 81990km/50946miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CGKA) Labels: 059-907-401-CAP.clb
Part No SW: 8K1 907 401 E HW: 8K1 907 401 A
Component: 2.7TDI EDC17 H02 0001
Revision: 15H02---
Coding: 0114002C18070118
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM27TDI8K1907401E A01001
ROD: EV_ECM27TDI8K1907401B.rod
VCID: 2E53E83371E29E6E36F-807B
1 Fault Found:
5227 - Fuel Rail/System Pressure
P0087 00 [096] - Too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AK HW: 8K0 907 379 AK
Component: ESP8 front H04 0070
Revision: -------- Serial number: --------------
Coding: 190500
VCID: 820BEC831DFA4A0E027-80D7
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0321
Revision: 00002001
Coding: 030000
VCID: 8109E38F18FC51161BD-80D4
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H36 0042
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 81091 km
Time Indication: 0
Date: 2014.08.08
Time: 23:58:42
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AP HW: 8T1 820 043 AP
Component: KLIMA 3 ZONEN H08 0160
Revision: C0000000 Serial number: 01290520091031
Coding: 36120000
Shop #: WSC 06192 000 00000
VCID: 7F0DE577EE08A7E6ED9-802A
Address 09: Cent. Elect. Labels: None
VCID: 55A167DFBCF48DB6975-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
Component: CDC-MP3-Pana H48 0050
Revision: 00000014
VCID: 2149030F383C3116BBD-8074
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39940915003926
Coding: 000001
VCID: 3E73D873A9826EEEA6F-806B
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H37 0520
Serial number: 003EFD03622F
Coding: 30313433363030303030554A304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4189A38FD07C1116DBD-8014
Crash sensor for side airbag; driver side:
Serial number: 6334MSME47432D38H
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME482471437
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME062E471CN
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME7B2C3F0A
Crash sensor for front airbag; driver side:
Serial number: 63732SME472B2B340
Crash sensor for front airbag; passenger side:
Serial number: 63832SME7C2D380CE
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304IES00055
Coding: 000016
VCID: 3D71DF7FA48475F6BF5-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 931 D HW: 8T0 920 931 D
Component: KOMBIINSTR. H33 0253
Revision: 00100000 Serial number: BYI40E769
Coding: 0F05000002000008010000
VCID: 387FCE6B8BA650DE6C3-806D
Address 19: CAN Gateway Labels: None
No Faults Found
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000008928598
Coding: 011C02224000120102
VCID: 4581B79FCC543D36E75-8010
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 29
Reset counter: 151
Mileage: 80858 km
Time Indication: 0
Date: 2014.08.04
Time: 19:02:35
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0118993952
Coding: 011A0680003904400120000000000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000008935950
VCID: 4487AA9BC76E043EF0B-8011
Address 53: Parking Brake
Cannot be reached
Address 55: Xenon Range
Cannot be reached
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 056 B HW: 4F0 035 056
Component: Radio U STD H45 0020
Revision: AB001007 Serial number: 342FS097615307
Coding: 010003020100000001
VCID: 1F4D05F70E4807E68D9-804A
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 666 D HW: 8T1 035 666 D
Component: H-BN-EU H41 0047
Revision: -------- Serial number: 483FZ097512708
Coding: 01010002000681ED01000B1E000000010000
VCID: 3B75D167BA907BC6811-806E
Subsystem 1 - Part No: 8R0 060 884 E
Component: EUR 2009/2010 5805
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Se me puderem ajudar a decifrar estes erros agradecia.
Pois, mas o que eu queria saber era o que significa o primeiro erro que eu mencionei, a que peça do carro...
Obrigado, então o erro quer dizer que a minha bateria está a dar as ultimas...
Obrigado pela ajuda
abraço
ahh ok, obrigado pela vossa ajuda, essa bateria realmente e muito mais barata e é um problema de facil resolução.
abraços
