Boas
hoje tive de volta da maquina a fazer um diagnósticocom o vag e apareceu-me estes erros!!
18107-powertrain missing!!!
Saturday,10,January,2009,20:22:04:59303
VAG-COM Version: Release 704.1
Address 03: ABS Brakes
Control Module Part Number: 8E0 614 517
Component and/or Version: ABS/ESP front 3429
Software Coding: 04255
Work Shop Code: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Saturday,10,January,2009,20:35:10:59303
Address 01: Engine
Control Module Part Number: 038 906 019 LJ
Component and/or Version: 1,9l R4 EDC G500SG 4910
Software Coding: 00002
Work Shop Code: WSC 63251
Additional Info: WAUZZZ8E64A213730 AUZ6Z0D0024844
1 Fault Found:
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 35-00 - -
Readiness: 0 0 0 0 1
01426 - Controls in Steering Wheel (E221)
01426 - Controls in Steering Wheel (E221): No Signal/Communication
Possible Symptoms
Multi-Function-Display (MFD) can not be operated
Possible Causes
Steering Column Control Module Supply Voltage insufficient
Fuse(s) faulty
Wiring/Connectors from/to Steering Wheel Controls faulty
Possible Solutions
Check Steering Column Control Module Supply Voltage
Check Fuse(s)
Check Wiring/Connectors from/to Steering Wheel Controls
Será fusivel?
Ajuda pede-se!!!!
1 Fault Found:
35-00 - -
Address 01: Engine
1 Fault Found:
P1699 - 35-00 - -
Possible Symptoms
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
Será fusivel?
Ajuda pede-se!!!!
