Ola pessoal, fiz um teste vag no meu argolas, a3 8l 1.9 110 Cv 99/09
Deu me um erro que me esta a preocupar porque mal arrancou aprece um luz vermelha deste género (!) no painel juntamente com a do ABS.... o teste deu isto o ABS é o modulo 3.
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 038 906 012 A
Component: 1,9l R4 EDC 0000SG 2801
Coding: 00002
Shop #: WSC 06435
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
1 Fault Found:
00668 - Supply Voltage Terminal 30
16-10 - Signal Outside Specifications - Intermittent
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 M
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 900
Component: KOMBI+WEGFAHRS. M73 D07
Coding: 00040
Shop #: WSC 00000
Ident.-Nr. Wegfahrs.:AUZ5Z0X7062204
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 L
Component: ZV-Pumpe D10
Coding: 00000
Shop #: WSC 06435
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 D
Component: Radio 0001
Coding: 00201
Shop #: WSC 00000
3 Faults Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
65535 - Internal Control Module Memory Error
00-00 - -
01044 - Control Module Incorrectly Coded
35-00 - -
Coding: 00002
Shop #: WSC 06435
Coding: 13304
Shop #: WSC 06435
1 Fault Found:
Coding: 00040
Shop #: WSC 00000
Coding: 00000
Shop #: WSC 06435
Coding: 00201
Shop #: WSC 00000
3 Faults Found:
00-00 - -
35-00 - -
