VW Eletricista Audi
Tópico em 'Eletrónica e VAG-COM' iniciado por alphasil, 14 Fev 2018.
  1. alphasil
    alphasil
    Desde:
    24 Jul 2007
    35
    Gostos Recebidos:
    2
    Olá
    Alguém conhece algum eletricista audi ?
    Zona de Viana do Castelo/Braga/Porto
  2. madlima29
    madlima29
    Desde:
    6 Jul 2009
    11 823
    Gostos Recebidos:
    3 777
    O que precisas exactamente?
  3. alphasil
    alphasil
    Desde:
    24 Jul 2007
    35
    Gostos Recebidos:
    2
    Boas
    Resolver umas cenas que me dão erro no a3 que tenho
    instalei o Acc e o lane assist e agora tenho erros no carro.
    Fui a bosch e tenho isso
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    3C-Lane Change -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    Address 01: Engine (2D2D2-CXXB) Labels: None
    Part No SW: 04L 906 056 D HW: 04L 907 445 B
    Component: R4 1.6l TDI H06 2510
    Revision: 22004001
    Coding: 02194012432401092000
    Shop #: WSC 20890 002 1048576
    ASAM Dataset: EV_ECM16TDI03004L906056D 002006
    ROD: EV_ECM16TDI03004L906056CQ_AU37.rod
    VCID: 2EB6D6B77918DD6267F2AB-807A
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
    Component: ESC H42 0623
    Revision: 00000000 Serial number: 60636000000863
    Coding: 12F162A224240A6D017B060241C82548462450806082A4F2024100788008
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
    ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
    VCID: 791C35EBF0D6CADA828060-802C
    Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
    Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
    Component: AC Automat H14 0060
    Revision: 20028000 Serial number: 00000000876659
    Coding: 03000104002000011000000000001100
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
    ROD: EV_AirCondiFrontVaAU37X.rod
    VCID: 328EC2C76D20F98203CA7F-8066
    Address 09: Cent. Elect. (J519) Labels: None
    Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
    Component: BCM MQBAB H H24 0175
    Serial number: 01061606301779
    Coding: 04040A42C24122FD43844004001C07A80008000000000000000000000000
    ASAM Dataset: EV_BCMMQB 015001
    ROD: EV_BCMBOSCH_AU37.rod
    VCID: 04E2541F87148732E11679-8050
    Slave 1:
    Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
    Component: WWS370 160208 043 0580
    Serial number: 160220190438
    Coding: 0A47F7
    Slave 2:
    Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0004
    Serial number: 61447609
    Coding: 00006C
    Slave 3:
    Subsystem 3 - Part No SW: 8V0 941 531 AE HW: 8V0 941 531 AE
    Component: E1 - LDS MQB H05 0032
    Serial number: 02 12 2015 00000025
    Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-283.clb
    Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
    Component: PARKHILFE 4K H10 0054
    Revision: -------- Serial number: 39291606300563
    Coding: 0000050001
    Shop #: WSC 09059 003 1048576
    ASAM Dataset: EV_EPHVA14AU3700000 002024
    ROD: EV_EPHVA14AU3700000_AU37.rod
    VCID: 3C92ECFFBF643FF2D966C1-8068
    Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
    Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
    Component: ACC Bosch MQB H05 0400
    Serial number: 09061503212718
    Coding: 00001B00FE0339
    Shop #: WSC 73430 031 00063
    ASAM Dataset: EV_ACCMRRBoschVW372 001016
    ROD: EV_ACCMRRBoschVW372_AU37.rod
    VCID: 3A9EEAE7B55001C2CB7AD7-806E
    5 Faults Found:
    15360768 - Component Protection
    U1101 00 [009] - Active
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 52
    Mileage: 45929 km
    Date: 2018.03.08
    Time: 12:00:48
    1024 - Databus
    U1123 00 [009] - Received Error Message
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 52
    Mileage: 45929 km
    Date: 2018.03.08
    Time: 12:00:48
    0284 - Databus
    U1121 00 [009] - Missing Message
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 52
    Mileage: 45929 km
    Date: 2018.03.08
    Time: 12:00:48
    1027 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 52
    Mileage: 45929 km
    Date: 2018.03.08
    Time: 12:00:48
    1028 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 52
    Mileage: 45929 km
    Date: 2018.03.08
    Time: 12:00:48
    Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
    Component: AirbagVW20 012 0361
    Serial number: 003M2R1HGWWN
    Coding: 98CCC0000C0000005C5400CA004800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
    ROD: EV_AirbaVW20SMEVW37X_AU37.rod
    VCID: 4B70BF23EACA884A60CC6A-801E
    Crash sensor for side airbag; driver side:
    Subsystem 1 - Part No SW: ----------- HW: 480 000 303 16
    Component: SideSensor_Df 001 0887
    Serial number: 357670000003C358C91
    Coding: 2D2D2D
    Crash sensor for side airbag; front passenger side:
    Subsystem 2 - Part No SW: ----------- HW: 480 000 303 16
    Component: SideSensor_Pf 001 0887
    Serial number: 358670000002B358C91.
    Coding: 2D2D2D
    Crash sensor for side airbag; rear; driver side:
    Subsystem 3 - Part No SW: ----------- HW: 480 400 503 16
    Component: SideSensor_Dr 001 6149
    Serial number: 3516502B51F93A03B33A
    Coding: 2D2D2D
    Crash sensor for side airbag; rear; passenger side:
    Subsystem 4 - Part No SW: ----------- HW: 480 400 503 16
    Component: SideSensor_Pr 001 6149
    Serial number: 3526502AF1F93A04B05K
    Coding: 2D2D2D
    Crash sensor for front airbag; driver side:
    Subsystem 5 - Part No SW: ----------- HW: 480 401 902 16
    Component: FrontSensor_D 001 6149
    Serial number: 3556502C11F3538392EG
    Coding: 2D2D2D
    Pedestrian protection crash sensor; driver side:
    Subsystem 6 - Part No SW: ----------- HW: 480 401 502 16
    Component: PedP_Sensor_D 001 6149
    Serial number: 22865029F1F1FF32C10S
    Coding: 2D2D2D
    Pedestrian protection crash sensor; front passenger side:
    Subsystem 7 - Part No SW: ----------- HW: 480 401 502 16
    Component: PedP_Sensor_P 001 6149
    Serial number: 2296502B71F353825066
    Coding: 2D2D2D
    Center pedestrian protection crash sensor:
    Subsystem 8 - Part No SW: ----------- HW: 480 401 002 16
    Component: PedP_Sensor_C 001 6149
    Serial number: 2306502A31F1FE312287
    Coding: 2D2D2D
    Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
    Part No SW: 8V0 953 521 EF HW: 5Q0 953 549 E
    Component: Lenks. Modul 003 0120
    Revision: -------- Serial number: 06031608490478
    Coding: A408
    ASAM Dataset: EV_SMLSKLOMQB 020001
    ROD: EV_SMLSKLOMQB_AU37.rod
    VCID: 02EE52079D008902D32A4F-8056
    Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
    Part No SW: 8V0 920 871 S HW: 8V0 920 871 S
    Component: KOMBI H03 6423
    Coding: 07A40A002B8800080600E8001000000000000000
    ASAM Dataset: EV_DashBoardVDDMQBAB 009051
    ROD: EV_DashBoardVDDMQBAB_AU37.rod
    VCID: 4C72BC3FEFC48F7269C611-8018
    1 Fault Found:
    13636608 - Control Module Incorrectly Coded
    U1014 00 [009] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 52
    Mileage: 45929 km
    Date: 2018.03.08
    Time: 12:00:56
    Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
    Component: GW MQB High 128 1244
    Revision: -------- Serial number: 0004542008
    Coding: 030100041F0873005B000248080B00000001010000000000000000000000
    ASAM Dataset: EV_GatewLear 013020
    ROD: EV_GatewLear.rod
    Alternator:
    Multifunction unit control module:
    Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
    Component: E221 - MFL H02 0014
    Serial number: 23 02 2016 A0071383
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
    Component: J367-BDMConti H02 1011
    Serial number: 74185704001602222986
    Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
    Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
    Component: SWA Master H05 0080
    Serial number: 0365205998
    Coding: 030321
    ASAM Dataset: EV_LaneChangAssis 001020
    ROD: EV_LaneChangAssis_AU37.rod
    VCID: 389AF0EF8B5C13D23D0E3D-806C
    Lane Change Assistant 2:
    3 Faults Found:
    388357 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 52
    Mileage: 45929 km
    Date: 2018.03.08
    Time: 12:00:47
    730378 - Warning Lamp for Lane Change Assistance in Driver-Side Ext. Mirror
    C1116 15 [008] - Open or Short to Plus
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 92
    Mileage: 45929 km
    Date: 2018.03.08
    Time: 12:10:25
    730634 - Warning Lamp for Lane Change Assistance in Passenger-Side Ext. Mirror
    C1117 15 [008] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 92
    Mileage: 45929 km
    Date: 2018.03.08
    Time: 12:10:25
    Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
    Component: TSG FS 020 0041
    Serial number: 210116EAG10603
    Coding: 00108B204000040000001002
    ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
    ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
    VCID: 43609703C29A400A989CB2-8016
    Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
    Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
    Component: EPS_MQB_ZFLS 125 1063
    Coding: 8103
    ASAM Dataset: EV_SteerAssisMQB 012140
    ROD: EV_SteerAssisMQB.rod
    VCID: 4462941FC7944732A196B9-8010
    Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
    Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
    Component: TSG BFS 020 0041
    Serial number: 150116EAE06466
    Coding: 001083204000040000001002
    ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
    ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
    VCID: 426E9207DD80490293AA8F-8016
    Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
    Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
    Component: LWR-ECU 005 0080
    Revision: -------- Serial number: --------------
    Coding: 018A000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
    ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
    VCID: 750439DBDCCEAEBAE6A85C-8020
    Address 5F: Information Electr. (J794) Labels: None
    Part No SW: 8V0 035 864 C HW: 8V0 035 864 B
    Component: MU-S-N-ER 042 0461
    Serial number: A3F00303161136
    Coding: 01730301FF00000021110001000A00002F0004040100010006
    ASAM Dataset: EV_MUStd4CPASE 002018
    ROD: EV_MUStd4CPASE_AU37.rod
    VCID: 3B90EFE3BA6A38CAD06CDA-806E
    Engine Control Module 2:
    Subsystem 1 - Part No SW: 8V0 919 866 D HW: -----------
    Component: ECE 2016 --- 0054
    Serial number: --------------------
    Seat Adjustment Driver Side:
    Subsystem 2 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
    Component: DU Std H49 0014
    Serial number: AUZ8Z9FY30FZ4E
    Sound System:
    Subsystem 3 - Part No SW: 8V0 919 614 P HW: 8V0 919 614 P
    Component: ControlUnit_B H41 0054
    Serial number: ALJAL116011600030256
    End-------------------------(Elapsed Time: 03:55)--------------------------
    Alguma dica?
  4. madlima29
    madlima29
    Desde:
    6 Jul 2009
    11 823
    Gostos Recebidos:
    3 777
    Qual o carro?
    Um 8V , certo?
    Se sim, tens de desbloquear a proteçao componente das peças que colocaste na audi.
  5. alphasil
    alphasil
    Desde:
    24 Jul 2007
    35
    Gostos Recebidos:
    2
    Sim é um 8V
    Como se faz isso??
    Não percebo nada disso
  6. madlima29
    madlima29
    Desde:
    6 Jul 2009
    11 823
    Gostos Recebidos:
    3 777
    Vais a audi desbloquear os componentes.
  7. alphasil
    alphasil
    Desde:
    24 Jul 2007
    35
    Gostos Recebidos:
    2
    Isso n dá para fazer com o vag-com??
  8. madlima29
    madlima29
    Desde:
    6 Jul 2009
    11 823
    Gostos Recebidos:
    3 777
    Só na audi.
  9. alphasil
    alphasil
    Desde:
    24 Jul 2007
    35
    Gostos Recebidos:
    2
    Boas
    Ja retirei a proteção,
    A questão é que codificação devo ter para isso funcionar?
    Mexer no 01 (engine)
    Mexer no 03 (ABS)
    agora depois de um scan dá-me isso
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 52 55 5F BB BC
    VIN: WAUZZZ8V7GAXXXX Mileage: 47131km-29285miles
    BB-Door Rear Drv -- Status: OK 0000
    BC-Door Rear Pass -- Status: OK 0000
    Address 01: Engine (2D2D2-CXXB) Labels:. 04L-907-309-V1.clb
    Revision: 22004001
    ROD: EV_ECM16TDI03004L906056_002_VW37.rod
    VCID: 2E53B8BA71174334BA-807A
    Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
    ROD: EV_Brake1UDSContiMK100IPB_034.rod
    VCID: 79F95BE6F8D9548C5F-802C
    Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
    VCID: 326BACCA652F67D4DE-8066
    Relative humidity sensor in fresh air intake duct:
    Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0005
    Serial number: 4FE8C81800PAG0MUFU01
    Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
    ROD: EV_BCMBOSCH_015.rod
    VCID: 04073A128F1B19643C-8050
    Control Unit For Wiper Motor:
    Coding: 0A47F7
    Rain Light Recognition Sensor:
    Coding: 00006C
    Light switch:
    Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
    Coding: 0000050001
    ROD: EV_EPHVA14AU3700000_002_AU37.rod
    VCID: 3C7782F2B76BA1A404-8068
    Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
    Coding: 00001B01FE033B
    ROD: EV_ACCMRRBoschVW372_VW26.rod
    VCID: 3A7B84EABD5F9F9416-806E
    6 Faults Found:
    1807 - No Enable Indentifications Active
    B2032 00 [009] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 67
    Mileage: 47128 km
    Date: 2018.03.12
    Time: 17:58:31
    Control Module temperature: 25 °C
    Voltage terminal 15: 12.4 V
    Vehicle speed: 0.00 m/s
    Acceleration: 0.00 m/s²
    1024 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 47128 km
    Date: 2018.03.12
    Time: 17:58:31
    0284 - Databus
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 47128 km
    Date: 2018.03.12
    Time: 17:58:31
    1027 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 47128 km
    Date: 2018.03.12
    Time: 17:58:31
    1028 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 47128 km
    Date: 2018.03.12
    Time: 17:58:31
    1792 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
    C1103 00 [009] - -
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 47128 km
    Date: 2018.03.12
    Time: 17:58:31
    Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
    ROD: EV_AirbaVW20SMEVW37X_VW37.rod
    VCID: 4B95D12EE2C5161CBD-801E
    Side Sensor Driver Front:
    Coding: 2D2D2D
    Side Sensor Passenger Front:
    Coding: 2D2D2D
    Side Sensor Driver Rear:
    Coding: 2D2D2D
    Side Sensor Passenger Rear:
    Coding: 2D2D2D
    Front Sensor Driver:
    Coding: 2D2D2D
    Pedestrian Protection Driver:
    Coding: 2D2D2D
    Pedestrian Protection Passenger:
    Coding: 2D2D2D
    Pedestrian Protection Center:
    Coding: 2D2D2D
    Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
    Coding: A408
    ROD: EV_SMLSKLOMQB_020_AU37.rod
    VCID: 020B3C0A950F17540E-8056
    Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
    Coding: 07A40A002F8000080600E8001000000000000000
    ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
    VCID: 4C97D232E7CB1124B4-8018
    1 Fault Found:
    U1014 00 [009] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 19
    Reset counter: 67
    Mileage: 47080 km
    Date: 2018.03.12
    Time: 10:03:40
    Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
    ROD: EV_GatewLear_013_VW37.rod
    Alternator:
    Multi Function Steering Wheel Control Module:
    Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
    Coding: 030321
    ROD: EV_LaneChangAssis_VW51.rod
    VCID: 387F9EE283538D84E0-806C
    Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
    Component: SWA Slave H05 0080
    Serial number: 0368405631
    Coding: 030321
    3 Faults Found:
    388357 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 64
    Mileage: 47080 km
    Date: 2018.03.12
    Time: 10:03:40
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 104
    Mileage: 47080 km
    Date: 2018.03.12
    Time: 10:09:49
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 104
    Mileage: 47080 km
    Date: 2018.03.12
    Time: 10:09:49
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    ROD: EV_DCUDriveSideEWMAXCONT.rod
    VCID: 4385F90ECA95DE5C45-8016
    Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
    Coding: 8103
    ROD: EV_SteerAssisMQB_012_VW37.rod
    VCID: 4487FA12CF9BD9647C-8010
    Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
    ROD: EV_DCUPasseSideEWMAXCONT.rod
    VCID: 428BFC0AD58FD7544E-8016
    Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
    ROD: EV_HeadlRegulVWLWRMQB.rod
    VCID: 75E157D6D4C130EC3B-8020
    Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
    ROD: EV_MUStd4CPASE_VW37.rod
    VCID: 3B7581EEB265A69C0D-806E
    Data medium:
    Display unit 1 for multimedia system:
    Multimedia Operating Unit:
    Address BB: Door Rear Drv (J388) Labels:* None
    Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
    Component: TSG HFS 020 0041
    Serial number: 150216BBF03042
    Coding: 000083204000040000001002
    ASAM Dataset: EV_DCURearDriveMAXKLO 006003
    ROD: EV_DCURearDriveMAXCONT.rod
    VCID: 4581E716C4A1E06C6B-8010
    Address BC: Door Rear Pass (J389) Labels:* None
    Component: TSG HBFS 020 0041
    Serial number: 150216BBF0304B
    ASAM Dataset: EV_DCURearPasseMAXKLO 006003
    ROD: EV_DCURearPasseMAXCONT.rod
    End-------------------------(Elapsed Time: 04:01)--------------------------
  10. PCOSTA
    PCOSTA
    Desde:
    3 Dez 2008
    2 733
    Gostos Recebidos:
    404
  11. PCOSTA
    PCOSTA
    Desde:
    3 Dez 2008
    2 733
    Gostos Recebidos:
    404
Partilhar esta página
