Tenho uma Audi A4 Avant B7 e após fazer um scan apareceu-me bastantes erros...
Alguns já consegui tirar as dúvidas, através de outros posts, mas outros não consigo perceber...
Aqui vão os erros:
E pronto, como podem ver são mesmo bastantes erros, o que me deixa um pouco preocupado...
Conto com a vossa ajuda para identificar estes erros.
Fiquem bem
Aqui vão os erros:
Code:
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 22373 124 50361
1 Fault Found
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 38.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 00101100
Temperature: 7.2°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Code:
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M003A4MR
Coding: 0033622
Shop #: WSC 06325 000 00000
2 Faults Found
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 8
Reset counter: 99
Time Indication: 0
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Code:
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
Component: RNS-E HIGH EU H58 0650
Revision: 11S Serial number: AUZBZ7F0482319
Coding: 0301215
Shop #: WSC 22373 124 89343
2 Faults Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 193
Time Indication: 0
Date: 2004.12.06
Time: 00:06:22
Freeze Frame:
Voltage: 12.60 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 193
Time Indication: 0
Date: 2004.12.06
Time: 00:13:31
Freeze Frame:
Voltage: 12.60 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Code:
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BR
Component: Komfortgerát T23 3132
Coding: 07024
Shop #: WSC 06325
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 1215
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
4 Faults Found
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
01331 - Door Control Module; Driver Side (J386)
53-10 - Supply Voltage Too Low - Intermittent
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
Code:
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301215
2 Faults Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 193
Time Indication: 0
Date: 2004.12.06
Time: 00:06:22
Freeze Frame:
Voltage: 12.60 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 193
Time Indication: 0
Date: 2004.12.06
Time: 00:13:31
Freeze Frame:
Voltage: 12.60 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Code:
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 C HW: 8E0 919 283 C
Component: Parkhilfe 8-Kan H06 0020
Revision: 00H06000 Serial number: 00067802120506
Coding: 0000114
1 Fault Found
01548 - Sensor for Parking Aid; Rear Right (G206)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 6
Reset counter: 174
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
Fiquem bem
