Boa tarde,
Acabei de adquirir um cabo Vag-Com 812.4 e sou um pouco inexperiente no assunto…
Consegui verificar os Km’s do A4 que comprei em Maio e que foi importado da Alemanha em 2006, espanto meu havia uma diferença de 22 Km
Neste momento o carro tem a luz do Air-Bag acesa e tenho de substituir a luz de stop trás lado esquerdo.
Portanto fiz um diagnóstico e ficou o seguinte:
VCDS Version: Beta 812.4
Data version: 20090214
Thursday,30,April,2009,12:13:28:26365
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E85A401103 Mileage: 81250km/50486miles
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC 0000SG 7002
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 00000 785 00200
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 HW: 8E0 614 517 AP
Component: ESP8 front H04 0170
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06335 000 00000
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AK
Component: A4 Klimaautomat 2728
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul ECE 0203
Coding: 01021
Shop #: WSC 06335
1 Fault Found
02738 - Bulb for Tail/Brake Light; Left
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 2620
Revision: 91H10262 Serial number: 0036M00012C3
Coding: 0033622
2 Faults Found
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 51
Reset counter: 99
Time Indication: 0
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 1
Fault Frequency: 77
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04011
Shop #: WSC 06335
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 D HW: 8E0 920 931 D
Component: KOMBI+WFS 4 H12 0030
Coding: 0004041
Shop #: WSC 11111 111 11111
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 46: Central Conv. Labels: None
Part No: 8E0 959 433 BJ
Component: Komfortgerát T23 2331
Coding: 06768
Shop #: WSC 06335
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0205
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 B
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000005
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 01025
Shop #: WSC 06335
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 D HW: 8P0 862 335 D
Component: FSE_255x BT H18 0050
Revision: 00000001 Serial number: 00000000111672
Coding: 0001611
Pelo que percebi para resolver os problemas:
•Substituir a lâmpada (ainda não sei como e entrada é muita pequena);
•Apagar os erros, desligar a ficha do air-bag que se encontro por baixo de banco condutor e ligar novamente, e fazer diagnostico outra vez.
Há mais alguma coisa que me escapou?
Obrigado pela ajuda.
69 75 76 77
Coding: 0000072
Coding: 0004401
Coding: 00000
Shop #: WSC 00000
Coding: 01021
Shop #: WSC 06335
1 Fault Found
Coding: 0033622
2 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 51
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 77
Time Indication: 0
Coding: 04011
Shop #: WSC 06335
Coding: 0004041
No Faults Found
Coding: 06768
Shop #: WSC 06335
Part No: 8E1959801B
Part No: 8E1959802B
Part No: 8E0959801A
Part No: 8E0959802A
Coding: 0000005
Coding: 01025
Shop #: WSC 06335
Coding: 0001611
