descodificar erros vag com - A3 8l vs Golf IV
Quem me puder ajudar agradeço
A3 8L
Part No: 038 906 018 BP
Component: 1,9l R4 EDC 0400SG 2110
Coding: 00002
Shop #: WSC 06313
VCID: 65C5B5A7D7A1
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 H
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
VCID: 366722EB3A87
Address 08: Auto HVAC Labels:
VCID: 55A5856787C1
Note: Excessive Comm Errors
Address 15: Airbags Labels: Redir Fail!
Part No: 8L0 959 655 F
Component: Airbag 7 Audi 0505
Coding: 00104
Shop #: WSC 06313
VCID: 418D41376349
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00595 - Crash Data Stored
35-00 - -
Address 17: Instruments Labels: 8L0-919-xxx-17.lbl
Part No: 8L0 919 860 D
Component: AB-KOMBIINSTR. VDO D10
Coding: 00040
Shop #: WSC 00000
VCID: 397D29D70B99
Subsystem 1 - Part No: IMMO
Component: IDENTNR: AUZ7Z0W0661119
IMMO-IDENTNR: AUZ7Z0W0661119
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D05
Coding: 00000
Shop #: WSC 51241
VCID: 397D29D70B99
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm; Close
29-00 - Short to Ground
01365 - Lock/Unlock Switch; Interior
01389 - Tailgate Open Switch (F124)
Agora o golf so consegui ate ao engine da erro de seguida ( n sei pq }
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Part No: 038 906 012 FB
Component: 1,9l R4 EDC 0000SG 3350
Coding: 00002
Shop #: WSC 01271
VCID: 55A585678218
WVWZZZ1JZ2W571751 VWZ7Z0A4658060
1 Fault Found
17970 - Quantity Adjuster (N146): Upper Limit Reached
P1562 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 01271 785 00200
VCID: 316D11F7D630
Chega de perguntas... Nem o rapaz se explicou e detalhou nada, nem sequer fez os scan completos e correctamente.
Fazer scans completos? como assim... tenho a vag com a 1 dia... ainda n percebo muito daquilo... sim sei q ele sofreu um acidente no anterior dono... em relaçao as luzes n esta nada aceso no painel ( acho estranho ) como faço na vag com scan automatico a todos os modulos?
se não tens luzes acesas no painel, algo deve estar mal, a luz do air bag pelo erro deveria ter a luz acesa, possivelmente nem deves ter os air bags funcionais, e deve ter ai uma marosca qualquer para a luz ñ acender, atenção isto é o que eu penso ;)
Pois, é estranho a luz n estar acessa.
Um membro aqui no forum, contou que uma vez abriu o painel e reparou que o led do airbag estava dessoldado. Soldou e ai é que reparou que o carro n estava a 100%.
Não tou a dizer que é o teu caso, mas é so para contar uma historia do que o pessoal é capaz de fazer.
Sinceramente, penso que isto é ilegal. Ainda a mais para quem compra um carro. Pensamos que podemos conduzir a vontade e que estamos protegidos e depois quando precisamos dos sistemas de segurança estes n actuam... e de quem e a culpa???
Foi comido. Alguem eliminou as luzes e vendeu o carro assim mesmo.
Pede ajuda a quem tem mais experiencia para te ver o carro com o vag.
