Como analisar/interpretar os dados do Scan de análise (Check up) do VAG-COM 15.7.1
Bom dia pessoal.
Sou o Nuno de Fátima e tenho um Audi modelo B7, 2.0 TDI.
Estou com um problema... Comprei o cabo VAG-COM versão 15.7.1, e fiz a análise ao meu carro. Mas agora não consigo interpretar os dados :(
Preciso da vossa ajuda... Alguém de Fátima ou perto de Fátima.
Os vidros elétricos não funcionam e o rádio RNSE MMI Plus não lê DVD do GPS.
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: Release 15.7.1 Data version: 20150904
Ross-Tech: Home
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Sunday,08,May,2016,17:43:57:05031
VIN: WAUZZZ............. License Plate:
Mileage: 137370km-85357mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ............ Mileage: 137370km-85357miles
------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 27570 142 86332
VCID: 75E679FB1CD291967E-8020
No fault code found.
Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 00000
VCID: 26446EB791F4AA0E07-8072
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0202
Hex Value: 0x00FF
Hex Value: 0xFF9B
Hex Value: 0x00FF
VCDS
Self-Diagnosis Log
Page 2
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AL
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 27952
VCID: 6BD25F831996576698-5000
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-00 - No Communications
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0304
Coding: 10001
Shop #: WSC 06325
VCID: 3B72AFC3297607E648-49D8
No fault code found. -------------------------------------------------------------------------------
VCDS
Self-Diagnosis Log
Page 3
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M0022V9W
Coding: 0033622
VCID: 3B72AFC37A7607E648-806E
Subsystem 1 - Serial number: 6332DRB4015246258
Subsystem 2 - Serial number: 6342DRB401514899L
Subsystem 3 - Serial number: 6352ARB400436178B
Subsystem 4 - Serial number: 6362ARB4004360376
Subsystem 5 - Serial number: 63729RB40044CAE2T
Subsystem 6 - Serial number: 63829RB40044C312A
1 Fault Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 99
Time Indication: 0
------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04042
Shop #: WSC 06325
VCID: 418EDD2B4B9A6D3612-49D8
2 Faults Found:
01303 - Telephone Transceiver (R36)
01301 - Control Module for Voice Recognition (J507)
VCDS
Self-Diagnosis Log
Page 4
VIN: WAUZZZ................ License Plate:
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 D HW: 8E0 920 931 D
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0006001
Shop #: WSC 73249 020 01196
VCID: 295E658B83EA85762A-5072
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
010 - Open or Short to Plus - Intermittent
004 - No Signal/Communication
------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006001
VCID: 295E658B83EA85762A-5000
2 Faults Found:
------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BG
Component: Komfortgerát T85 2431
Coding: 07024
Shop #: WSC 06325
VCID: 77FA73F355DEE3866C-4A3A
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
1 Fault Found:
00956 - Key 2
35-00 - -
End-------------------------(Elapsed Time: 07:26)------------------
Re: Como analisar/interpretar os dados do Scan de análise (Check up) do VAG-COM 15.7
Quanto as vidros, já viste se tens algum fusível queimado?
é que não aparece nenhum erro relativo a esse problema...
Luzes de ABS/ESP airbag, não tens nada aceso?
apaga os erros todos, e volta a fazer SCAN passado uns kilometros de andares com a viatura..
Obrigado pela resposta vick_79
Em relação aos fusíveis está tudo em alemão, o carro foi importado da Alemanha, fazes alguma ideia de onde fica o fusível e qual o número do fusível dos vidros?
Não aparece nenhuma luz no painel de instrumentos (quadrantes).... ABS/ESP ligam quando ligo a chave, mas depois quando ligo o carro desaparecem....
Vick_79 como é que apago os erros no VAG-COM 15.7.1?
Um abraço
Nuno Mendes
Um abraço
Nuno Mendes
Lista de fusíveis não te sei dizer, mas sempre podes ver um a um..
Quanto apagar os erros, apos teres feito "auto-scan" carregas em "clear all DTCs" do lado esquerdo, como esta na foto..
[/IMG]
Obrigado vick_79 pela dica 8)
Já limpei os erros todos e continua a não funcionar... :(
VCDS
VCDS Version: Release 15.7.1 Data version: 20150904 www.Ross-Tech.com
Dealer/Shop Name:
Self-Diagnosis Log Monday,09,May,2016,21:34:36:05031
VIN: WAUZZZ8E License Plate: Mileage: 137400km-85376mi Repair Order:
67 69 75 76 77
VIN: WAUZZZ8E Mileage: 137400km-85376miles
Part No SW: 03G 906 016 GN HW: 028 101 211 3 Component: R4 2,0L EDC G000SG 9618
Coding: 0000072
Shop #: WSC 27570 142 86332 VCID: 75E679FB1CD291967E-8020
Readiness: 0 0 1 1 1
Coding: 0004401
Shop #: WSC 06325 000 00000 VCID: 26446EB791F4AA0E07-8072
Coding: 00000
Shop #: WSC 27952 VCID: 6BD25F831996576698-5000
VCDS
Self-Diagnosis Log
Monday,09,May,2016,21:34:36:05031Page 2
Coding: 10001
Shop #: WSC 06325
VCID: 3B72AFC3297607E648-4A3A
Coding: 0033622
Subsystem 6 - Serial number: 63829RB40044C312A No fault code found.
-------------------------------------------------------------------------------Address 16: Steering wheel Labels: 8E0-953-549.lbl
Coding: 04042
Shop #: WSC 06325
VCDS
Self-Diagnosis Log
Page 3
Coding: 0006001
Shop #: WSC 73249 020 01196 VCID: 295E658B83EA85762A-5000
-------------------------------------------------------------------------------Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006001
Shop #: WSC 73249 020 01196 VCID: 295E658B83EA85762A-5072
-------------------------------------------------------------------------------Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Coding: 07024
Shop #: WSC 06325
Subsystem 2 - Part No: 8E1959802B Component: Tõrsteuer.BF BRM 0205
End-------------------------(Elapsed Time: 07:31)-----------------------
VCDS
VCDS Version: Release 15.7.1 Data version: 20150904 Ross-Tech: Home
Dealer/Shop Name:
67 69 75 76 77
Coding: 0000072
Coding: 0004401
Coding: 00000
VCDS
Self-Diagnosis Log
Coding: 10001
Shop #: WSC 06325
Coding: 0033622
Coding: 04042
Shop #: WSC 06325
VCDS
Self-Diagnosis Log
Page 3
Coding: 0006001
Coding: 0006001
Coding: 07024
Shop #: WSC 06325
Mas isso já era de esperar que não resultasse, não tinhas erros relacionados com o problema, a causa do problema deve ser fusível, se não sabes qual é o fusível, faz a visualização um a um.. isso aconteceu nada? existe mais alguma coisa que não funcione no carro?
O sistema RNS-e não está a funcionar o DVD do GPS
Parece que sim...
